Replace style with library style
I am trying to find a way to replace a used style with an existing library style. For drawing documents I saw that a function name "Replace style" exists in "Style and Standard Editor" window. Is this functionality allowed in API? If not how can I replace a style with another style using API.
Sorry, there isn't an API equivalent for the
'Replace style" command. You will need to do the replacement on a per object
basis. For instance, use the GeneralNote.TextStyle property to change
the style used by a drawing note.However, the API doesn't provide this support
for all objects yet.
Sanjay-
This is a really bad news. Isn't there a way to do this easier and better - like calling the Inventor "Replace style" method?
Do you know if the "Replace Style" function will be available in the 2010 Inventor API?
Sorry, but no, this is not available in Inventor
2010 either.
Sanjay-
