Replace Sketch Symbol retain reference to attached entity
I am writing a quick program that replaces a sketch symbol in a drawing. I am able to query the old symbol's position and use that however, the old symbol is attached to a leader note via geometry intent. How can I query the leader note from the old symbol so I can recreate the intent and have the new symbol attach to the same leader note?
Any help appreciated. Let me know if more information is needed.
-Chris
Figured it out. Posting for reference.
//returns the GeometryIntent of the node, in this case it is the node @ index 2 (this is where I was confused since I was using index @1 but this returns the first node of your leader which is not what is attached to the leader note mentioned above)
object intent = oldSymbol.Leader.AllNodes[2].AttachedEntity;
Once the object was returned I used that as a point in my new sketchsymbol to insert it and the new symbol is attached to the intent
