Replace Refference problem
markohog
markohog
Hi
I amtrying to replace the reffernce of the unroslved file in the assembly
C:\Users\Marko\Desktop\3D\Workspace\Assembly3_6\Sklop\Assembly3_n1
When i run the rule in this file it won't replace the reference, but if i change the line higlithed in red
to any other file this code works.
I have attached the files in the attachment
This is driving me crazy please help
Sub Main()
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As ComponentDefinition
oCompDef=oDoc.ComponentDefinition
Dim occ As ComponentOccurrence
For Each occ In oCompDef.Occurrences
	If occ.Name="" Then GoTo 1:
	If occ.IsSubstituteOccurrence = "True" Then GoTo 1 :
	Try
	If occ.Definition.Type =ObjectTypeEnum.kWeldsComponentDefinitionObject Then GoTo 1:
	Catch
	End Try
	If occ.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		occ.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference("C:\Users\Marko\Desktop\Reduktor1\Workspace\Assembly3_6\Assembly3_n1.iam")
1:
Next
End Sub
markohog
The files i want to copy are attached in the post above.
markohog
Anyone?
JelteDeJong
According to the help files: "The file being replaced and the replacement file must share ancestry (i.e. they must have the same InternalName). Documents have the same internal name if they are copied using 'Save Copy As' or a file explorer copy." I did not check your files but I guess that is the problem. As a test, you could check the internal names of the old and new files. Try the following rule:
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
For Each occ As ComponentOccurrence In oCompDef.Occurrences
	If occ.Name = "" Then Continue For
	If occ.IsSubstituteOccurrence Then Continue For
	Try
		If occ.Definition.Type = ObjectTypeEnum.kWeldsComponentDefinitionObject Then Continue For
	Catch
	End Try
		Dim refDOc As Document = occ.ReferencedDocumentDescriptor.ReferencedDocument
		Dim orgInternalName = refDOc.InternalName
		Dim newFileName = "D:\forum\2022\exampleFile\AngleSupportPair.iam" ' "C:\Users\Marko\Desktop\Reduktor1\Workspace\Assembly3_6\Assembly3_n1.iam"
		Dim newDoc As Document = ThisApplication.Documents.Open(newFileName)
		Dim newInternalName = newDoc.InternalName
		newDoc.Close(True)
		If (orgInternalName <> newInternalName) Then
			MsgBox("The file being replaced and the replacement file must share ancestry (i.e. they must have the same InternalName)")
		Else
			occ.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(newFileName)
Next
Jelte de Jong
Blog: hjalte.nl - github.com
markohog
The files share an ancestry (Replace reference file is a copy of the unresolved file). I have tried to get the internal name of the unresolved file but it returns an error.
The problem is with the naming of the file. The files have the same name in the workspace
The main file Assembly3_n1.iam has the path:
C:\Users\Marko\Desktop\3D\Workspace\Assembly3_6\Sklop\Assembly3_n1.iam
And  the resolve file has the path:
 C:\Users\Marko\Desktop\3D\Workspace\Assembly3_6\Assembly3_n1.iam
If  I change the resolve file name to Assembly3_n1-copy :
C:\Users\Marko\Desktop\3D\Workspace\Assembly3_6\Assembly3_n1-copy.iam
The code will work.
I don't know why can't change the reference to this path
