Replace obsolete component
mcgyvr
Consultant Consultant
mcgyvr
Looking for some help on creating some ilogic code to replace obsolete components in assemblies when the assembly is opened and it contains that part.
Currently I've just add this simple code to each component that is obsolete so when I open an assembly it "reminds" me to manually replace it
MessageBox.Show ("0200058003 is Obsolete" & vbLf & "Please replace with 0230061111", "OBSOLETE ALERT", MessageBoxButtons.OKCancel, MessageBoxIcon.Error)
BUT.. Now I'd like to see if there is a way so that when an assembly is opened with an obsolete part that it will automatically replace it.
Tried this but it doesn't work (note this code is located in the obsolete part file not in the assembly..
MessageBox.Show("0200058003.ipt is obsolete", "Obsolete")
'Run this only if this is an assembly.
doc = ThisDoc.ModelDocument
If doc.DocumentType = kAssemblyDocumentObject Then
Component.Replace("0200058003", "0230061111.ipt", True)
MessageBox.Show("0200058003 has been replaced", "Obsolete Replaced")
Vladimir.Ananyev
If your rule is located in the obsolete part file then ThisDoc.ModelDocument returns the reference to the PartDocument, not AssemblyDocument.  This explains why your Component.Replace method is never called.  You should run this rule in the context of an assembly document.
BTW ThisDoc.ModelDocument property normally assumes that ThisDoc is a drawing document.  Then it returns the model document (part or assembly) that is shown in a drawing document.  In your case it is better to use ThisDoc.Document property.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
mcgyvr
(ilogic newbie alert Smiley Very Happy )
So I got this code to work but would just like comments,improvement suggestions, etc.. on if there is a better/cleaner way (as again I'm new to ilogic)
But I set it up so that when I have an obsolete part I will add a new custom iprop to it and the value will be the replacement part.
Then this rule will be an external rule that I can run from any assembly.
It looks for any parts that have that custom iprop and then grabs the occurrence name and performs the componet replace function..
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
Try
   Dim oName As String 'create new string variable of oName
    oName = oOccurrence.Name 'get name of each occurrence
    Replacement = iProperties.Value(oOccurrence.Name, "Custom", "Obsolete_Replacement") 'grab the replacement part
    Component.Replace(oName,Replacement, True) 'replace the obsolete part with the replacement part
Catch
End Try
Next
I feel like there should be a better (cleaner) way instead of running into the catch for any parts that don't have that custom iprop.
I'd like to incorporate something that "if" the custom iprop is found.. "then" do the component replace.. And maybe thats what I have already but am not sure if thats the best way to handle that statement.
Thanks for any help/comments/improvements.
Vladimir.Ananyev
You may consider the following code sample as a start point:
'external rule must always check the type of the active document
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MsgBox("This rule work with assemblies only")
	Exit Sub
'top-level assembly document
Dim oAsmDoc as AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim n As Integer = 0  'counter
'Iterate through all of the occurrences at the top level
For Each oOcc As ComponentOccurrence In oAsmDef.Occurrences
	'get name of this occurrence
	Dim Name As String  = oOcc.Name
	Try
		'read custom iProperty value
    	        Dim Replacement As String  = iProperties.Value(oOcc.Name, "Custom", "Obsolete_Replacement")
		Try
			Component.Replace(oName, Replacement, True)
			n += 1 'increment counter
		Catch
			'replacement failed
			MsgBox(oOcc.Name & vbNewLine & "replacement failed for some reason")
		End Try
	Catch
		'custom property "Obsolete_Replacement" was not found
		'replacement not required
	End Try
Next
MsgBox("DONE:  " & vbNewLine & n & " occurrences replaced")
This code will do a lot of unnecessary extra work if you have many copied occurrences. So it obviously could be enhanced, but this requires more programming using the Inventor API.
Cheers,
Vladimir Ananyev
mcgyvr
Thanks!!!
Thats exactly the kind of "enhancement suggestions" I was looking for..
mcgyvr
	Exit Sub
	Try
		Try
		Catch
			'replacement failed
		End Try
	Catch
	End Try
Next
Cheers,
One small typo
Should be
Dim oName As String  = oOcc.Name
But it works great after thats fixed
Vladimir.Ananyev
Thank you for this correction!  Smiley Happy
cheers,
Vladimir Ananyev
