Replace component by VBA and Imates !!!!!!!!!! HELP !!!!!!!!!!!
Our basic product is a combination from several assemblies which are placed on Composit Imates. For each project we have to customize this product by replacing components. When I activate "replace component", I get the warning "Possible Constraint Loss", I confirm with "OK" and the sub-assembly is replaced correct. The problem is that the VBA code does not wait for the warning box, so I can not activate OK to accept the warning. What can I do to prevent or to accept this warning ?
What happens, if you set
Application::SilentOperation to true?
Steffen Pudor
Our
Steffen, thanks for the suggestion.
We tried this, but it does not suppress the message.
It is possible to avoid the Messagebox with warning when replacing components/assembly's by using the next sample code:
Dim oOccurrence as ComponentOccurrence
Set oOccurrence = ThisApplication.ActiveDocument.
.ComponentDefinition.Occurrences.Item(1)
oOccurrence.Replace C:\Temp\Part2.ipt", True
ThijsR (Holland)
The fact that SilentOperation does not work in this
case is a bug.  I've filed a defect.
-Brian
Steffen,
message.
