Replace borders in older drawings using iLogic
wilson.broeksema
wilson.broeksema
I've create 5 new custom borders named A4, A3, A2, A1 and A0. I've stored them in to template standard.dwg.
For older drawings I'd like to replace the border with one of the previous ones matching the sheet size.
If this can be done automatically that would be great, but I'm also satisfied if I get an arraylist with choices.
I've already created some code. It deletes the border and copies the resources from the template. It also comes up with an arraylist. As said, the arraylist is not neccessary.
Who can help me finishing the code?
'delete sheet formats
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveEditDocument
Dim oCurrentNumber  As Sheet
oCurrentNumber = oDoc.ActiveSheet
' Iterate through the sheets, and delete the title blocks and symbols
Dim oSheet As Sheet
For Each oSheet In oDoc.Sheets
    oSheet.Activate
Try
oSheet.Border.Delete
Catch
'catch error if no border found
End Try
ThisDrawing.ResourceFileName = "\\nlassapp04\Data\NXTdim\InvSet2016\Templates\standard.dwg"
ThisDrawing.KeepExtraResources = True
Dim resu1t As String="Result"
Dim T1TLE As New ArrayList
T1TLE.Add("A4")
T1TLE.Add("A3")
T1TLE.Add("A2")
T1TLE.Add("A1")
T1TLE.Add("A0")
resu1t=InputListBox("Select Drawing Border", T1TLE, resu1t, _
Title := "Border", ListName := "Borders from Template")
Next
Thanks in advance.
Wilson
blandb
Since you have your resource file defined, you should be able to use:
Change Border function:
ActiveSheet.Border="<New Border Name>"
Or
Change Border (2) - Incorporate prompted entries:
ActiveSheet.SetBorder("<New Border Name>", "promptedEntry1", "promptedEntry2")
Autodesk Certified Professional
mcgyvr
Have you looked into just using the "Drawing Resource Transfer Wizard" utility located in your start menu Inventor folder..?
wilson.broeksema
Yes I did, but not applicable since all our drawings are in Vault and in different folders.
