Repeat procedure for Sketches 1 To 7
TobFischer94
Message 1 of 11
TobFischer94
i got a procedure that uses the command "auto dimension and constraints" for my sketch geometry and then presses the apply button.
Dim oCommandMgr As CommandManager
    oCommandMgr = ThisApplication.CommandManager
Dim oControlDef As ControlDefinition
oControlDef = oCommandMgr.ControlDefinitions.Item( _
                                                 "SketchAutoDimensionCmd")
Dim oKCmd As ControlDefinition
oKCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_OKCmd")
Call oControlDef.Execute Call oKCmd.Execute
But for some reason when i try to use his procedure on more of my Sketches "Sketch1", "Sketch2", ..., ..., "Sketch7" using a for...next Loop it only applies them to Sketch 7.
Im doing something wrong since i only use little bits of code i found online.
I tried this: https://forums.autodesk.com/t5/inventor-customization/select-and-activate-sketch-via-ilogic/td-p/528... but it doesnt work in my case. My problem seems to be activating and editing Sketch by Sketch.
Any ideas? Help would be very appreciated.
Replies (10)
Message 2 of 11
Sergio.D.Suárez
I think you've discovered an bug, is it possible @JaneFan ?
I have tried some alternative paths and generates the error that closes the program when it enters a loop, it only seems to continue when an exit for is applied to escape the loop. The following routines should work, I guess, but all end in error
Dim doc As PartDocument
doc = ThisDoc.Document
Dim oSketch As PlanarSketch
oControlDef = oCommandMgr.ControlDefinitions.Item("SketchAutoDimensionCmd")
Dim oEditsketch As ControlDefinition
oEditsketch = ThisApplication.CommandManager.ControlDefinitions.Item("SketchEditSketchCtxCmd")
Dim oFinishSketch As ControlDefinition
oFinishSketch = ThisApplication.CommandManager.ControlDefinitions.Item("FinishSketch")
For Each oSketch In doc.ComponentDefinition.Sketches
oCommandMgr.DoSelect(oSketch)
oEditsketch.Execute
oControlDef.Execute
oKCmd.Execute2(True)
oFinishSketch.Execute
Next
Dim ocount As Integer = doc.ComponentDefinition.Sketches.Count
Dim i As Integer
For i = 1 To ocount
	osk= doc.ComponentDefinition.Sketches.Item(i)
	osk.edit
	oControlDef.Execute
	osk.exitedit
Next
Dim oSketch As Sketch
oSketch.edit
oControlDef.Execute
oSketch.exitedit
Next
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 11
TobFischer94
/Bump
Message 4 of 11
TobFischer94
/Bump
Message 5 of 11
Sergio.D.Suárez
Hi, since no one answers I will try to see an alternative path
Mechanical Designer
Message 6 of 11
Sergio.D.Suárez
This code was working for me, it's not exactly what you're looking for but it works fine, I'll keep testing until I can find something that works better
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Line1 :
Dim oApply As ControlDefinition
oApply = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_ApplyCmd")
Dim oDone As ControlDefinition
oDone = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_DoneCmd")
Dim oCancel As ControlDefinition
oCancel = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_CancelCmd")
For Each oSketch In oDoc.ComponentDefinition.Sketches
	If oSketch.ConstraintStatus <> 51713 Then
	oSketch.edit
	oControlDef.Execute
	oApply.Execute2(True)
	oCancel.Execute2(True)
	oSketch.exitedit
	Exit For
Next
question = MessageBox.Show("Repeat again", "Dimension Sketch",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If question = vbYes Then GoTo Line1 :
Mechanical Designer
Message 7 of 11
TobFischer94
it works for me too. Maybe we can go around the bug by also automating the pressing of the "Yes" button on the messagebox you implemented for the same amount of times as quantities of sketches exist? And Then automate the pressing of the "No" button to make the messagebox go away...
Message 8 of 11
Sergio.D.Suárez
Hi @YuhanZhang , could you check this thread? I am not an expert or anything similar in this forum, I have learned only from being self-taught, and in this thread I have found problems, that surely you have an accurate answer. Sorry for the inconvenience to call you from here. regards
Mechanical Designer
Message 9 of 11
YuhanZhang
Hi Sergio,
I just created a VBA sample to do the auto-dim for sketches, you can try it there after opening your part:
Sub AutoDimSk()
    Set oDoc = ThisApplication.ActiveDocument
    Set oCommandMgr = ThisApplication.CommandManager
    Set oControlDef = oCommandMgr.ControlDefinitions.Item( _
    Set oKCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_OKCmd")
    Dim oSk As PlanarSketch
    For Each oSk In oDoc.ComponentDefinition.Sketches
        oSk.Edit
        Call oKCmd.Execute
        ThisApplication.UserInterfaceManager.DoEvents
        oSk.ExitEdit
    Next
    ThisApplication.CommandManager.StopActiveCommand
End Sub
I think you can convert it to your addin also. Please let me if it works well there.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 10 of 11
TobFischer94
works perfectly.
Thank you very much!
Message 11 of 11
Sergio.D.Suárez
It works excellent, you are a genius @YuhanZhang , thank you for bothering to answer us.  I send you a warm greeting
Mechanical Designer
