Renew thumbnails for Inventor
GeorgK
Advisor Advisor
GeorgK
Hello togehter,
how could I update the thumbnail in the file? The view should be isometric.
Thank you very much
Georg
xiaodong_liang
Autodesk Support
Autodesk Support
When document is being saved, the new thumbnail will be generated with the current view. So you could just change the camera to the view you desired and call Document.Save.
Sub test()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.activeDocument
    Dim view As view
    Set view = ThisApplication.ActiveView
    Dim camera As camera
    Set camera = view.camera
    camera.ViewOrientationType = kRightViewOrientation
    camera.Fit
    camera.Apply
    oDoc.SetThumbnailSaveOption kActiveWindowOnSave
    oDoc.Save
End Sub
or, you can create or change the thumbnail with the bimap you want:
Public Function ChangeThumbnail(FullFileName As String)
' Set a reference to the active document
Dim odoc As Document
Set odoc = ThisApplication.ActiveDocument
' Get the "Summary Information" property set
Dim oPropSet As propertySet
Set oPropSet = odoc.propertySets("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}")
' Get the "Thumbnail" property
Dim oProp As Property
Set oProp = oPropSet.ItemByPropId(17)
Dim oDisp As IPictureDisp
Set oDisp = LoadPicture(FullFileName)
' Set the value of the thumbnail file property
oProp.value = oDisp
' Save the document
odoc.Save
End Function
GeorgK
Thank you very much.
