Render Style in Assembly Part
mk92
mk92
i have written some code and it works well until the last line. The Name of the Feature is shown correctly but the RenderStyle doesn't change to Yellow.
The Error is: Wrong Parameter
Anyone any idea whats the problem?
Regards
Code:
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOccurrence As ComponentOccurrence
oOccurrence = oAsmCompDef.Occurrences.Item(1)
Dim oPartDoc As PartDocument
oPartDoc = oOccurrence.Definition.Document
' Get the second feature.
Dim oFeature As PartFeature
oFeature = oPartDoc.ComponentDefinition.Features.Item(1)
MessageBox.Show(oFeature.Name)
oFeature.SetRenderStyle(kOverrideRenderStyle, oPartDoc.RenderStyles.Item("Yellow"))
jacob39NGR
  1. Ensure kOverrideRenderStyle is a valid constant for SetRenderStyle.
  2. Verify "Yellow" exists in oPartDoc.RenderStyles. You can loop through oPartDoc.RenderStyles to check.
  3. Confirm oFeature supports the SetRenderStyle method.
  4. If the feature type is known, consider type casting oFeature
