Renaming the Sheet With a Prompted Entry
Hi Everyone,
In my Title Block, I have a field called Sheet Name that is driven off of a prompted entry.  I was hoping to pull the text in that field and use it to also rename the sheet in the browser.  I tried looking around the forums but, couldn't find the answer.
If anyone can point me in the right direction, I would be very appreciative.
Paul
Sergio.D.Suárez
Hi, Could you attach an image to better describe the problem? to know the name, type of entry. Regards!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank's for replying.
I'm not sure what you need so, I apologize if I give you too much info.
When I first open a drawing or create a new sheet, I get a dialog box asking for the Sheet Name.  The Sheet Name Property Field is a labeled as Prompted Entry.  It isn't pulling from a regular or custom iProperty field.
Whatever is entered here, is put into the Title Block.
Here is a image of the Format Text window for more info
We are hoping to get the name given to the sheet (ABC123) to automatically pop up as the sheet name in the Browser to the left.
I hope that helped explain it a little better.
Paul
dean.morrison
I think this might do what you want.. Its VBA so may need modification if you want iLogic.
Set oDrawingDoc = ThisApplication.ActiveDocument
If oDrawingDoc.DocumentType = kDrawingDocumentObject Then
Set oSheet = oDrawingDoc.ActiveSheet
Dim oTitleBlock As TitleBlock
Set oTitleBlock = oSheet.TitleBlock
If Not oTitleBlock Is Nothing Then
Set oSketchDef = oTitleBlock.Definition.Sketch
Set oTextBoxes = oSketchDef.TextBoxes
For j = 1 To oTextBoxes.Count
If oTextBoxes.Item(j).Text = "<SHEET NAME>" Then
Set iTextBox = oTextBoxes.Item(j)
RequiredText = oTitleBlock.GetResultText(iTextBox)
Next j
Dim oPane As BrowserPane
Set oPane = oDrawingDoc.BrowserPanes.Item(1)
Dim oNode As BrowserNode
Set oNode = oPane.TopNode.BrowserNodes.Item(2)
oNode.NativeObject.Name = RequiredText
Hope that helps.
Dean.
Thank you! Looking through the code, it seems to be what I am looking for.  However, after i removed the Let and Set commands (Inventor doesn't like them anymore) I get the following error;
Error in rule: Rule0, in document: Drawing2
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Below is the code I am running.  I'm not sure what Parameter it is looking for.  Is the "J" in the code calling out the cell in the titleblock?  Is the parameter the error referring to the <SHEET NAME>?
Next j
Thanks again for your help,
Paul
I found a pretty decent work around here.  Thanks again for your help though.  You make these forums amazing.
