Renaming components in assembly
philippe.lagrue
Message 1 of 17
philippe.lagrue
I have tried this code for renaming all components in an assembly :
Class ChgDisplayName
	Public name As String = "Part "
	Public cpt As Integer = 1
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	Dim oOcc As ComponentOccurrence
	'Start a Transaction to bundle all the name changes into a single item in the 'Undo' menu.
	Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oADoc, "Rename Components")
	'rename all comps in top level first
	For Each oOcc In oADef.Occurrences
		RenameOcc(oOcc)
	Next
	'now try to rename comps at deeper levels
		If oOcc.SubOccurrences.Count > 0 Then 'it is a sub-assembly
			'run 'recursive' sub here
			'and supply the SubOccurrences to it
			Iterate(oOcc.SubOccurrences)
	Next
	'end the Transaction
	oTransaction.End
End Sub
Sub RenameOcc(oComp As ComponentOccurrence)
	'create new variable to enable 'Intellisense' recognition
	Dim oCO As ComponentOccurrence = oComp
	'get the PN
	Dim oCODoc As Document = oCO.Definition.Document
	'Dim oPN As String = oCODoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
	Dim oPN As String = name & cpt
	'check if PN is empty (not filled in)
	If oPN = "" Or oPN = " " Then
		MsgBox("Occurrence '" & oCO.Name & "' has an 'Empty' Part Number." & vbCrLf & _
		"Leaving original component name as it was.", , "")
		'oPN = oCO.Name
		Exit Sub
	'attempt to rename the component
	Dim oWorked As Boolean = False
	Try
		oCO.Name = oPN
	Catch
		Dim oInt As Integer = 0
		Do Until oWorked = True
			oInt = oInt + 1
			Try
				oCO.Name = oPN & ":" & oInt
				oWorked = True
			Catch
				oWorked = False
				If oInt > 10 Then
					oWorked = True
			End Try
		Loop
	Catch
		MsgBox("Failed to rename:  " & oCO.Name,,"")
	End Try
	If oWorked Then
		cpt += 1
End Sub
Sub Iterate(oOccs As ComponentOccurrencesEnumerator)
	Dim oComps As ComponentOccurrencesEnumerator = oOccs
	'try to rename all comps at this level first
	For Each oCO In oComps
		RenameOcc(oCO)
	Next
	'now loop through again checking for SubOccurrences, then Iterate
		If oCO.SubOccurrences.Count > 0 Then 'it is a sub-assembly
			Iterate(oCO.SubOccurrences)
	Next
End Sub
End Class
But it don't work for internal parts of an iAssembly :
Do you know why ?
Is there a solution ?
Accepted solutions (3)
Replies (16)
Message 2 of 17
ts2.cad3
 try to use this Sub main instead:
Sub Main
		Exit Sub
	'Dim oOcc As ComponentOccurrence
	'rename all comps
	For Each oOcc As ComponentOccurrence In oADef.Occurrences.AllReferencedOccurrences(asmDef).OfType(Of ComponentOccurrence)
	RenameOcc(oOcc)
Next
Message 3 of 17
philippe.lagrue
Thank you for the answer.
Here is the result (components are partially renamed) :
And in fact the program is aborted by this error
The code modified as you suggest :
Sub Main
		Exit Sub
		RenameOcc(oOcc)
	Next
		RenameOcc(oOcc)
	Next
	oTransaction.End
End Sub
You can find the assembly in the link below.
Message 4 of 17
ts2.cad3
ok some bugs deleted now:
Sub Main
		Exit Sub
	'MessageBox.Show("1", "Title")
	'rename all comps
	For Each oOcc As ComponentOccurrence In oADef.Occurrences.AllReferencedOccurrences(oADef).OfType(Of ComponentOccurrence)
	RenameOcc(oOcc)
Next
End Sub
	'MessageBox.Show("2", "Title")
	'get the PN
		'MessageBox.Show("3", "Title")
		'oPN = oCO.Name
		Exit Sub
	Try
		oCO.Name = oPN
		'MessageBox.Show("4", "Title")
	Catch
		'MessageBox.Show("5", "Title")
			oInt = oInt + 1
			Try
				oWorked = True
			Catch
				oWorked = False
				If oInt > 10 Then
					oWorked = True
			End Try
		Loop
	Catch
	End Try
	If oWorked Then
		cpt += 1
End Sub
Message 5 of 17
JhoelForshav
Hi @philippe.lagrue
It seems like something like this should be enough to accomplish what you're trying to do?
Dim name As String = "Part"
Dim num As Integer = 1
Dim def As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
For Each oOcc As ComponentOccurrence In def.Occurrences.AllReferencedOccurrences(def)
	Try
		oOcc.Name = name & num
		num += 1
	Catch
		MsgBox("couldn't rename " & oOcc.Name)
	End Try
Next
Message 6 of 17
philippe.lagrue
Thank you for your patience and interest.
The issue remain the same; impossibility to rename the components inside the iAssembly.
Message 7 of 17
philippe.lagrue
Thank you Jhoel.
But it's not the subject of my worry.
Message 8 of 17
JhoelForshav
I just made a more robust rule that also renames the occurrences in order in the tree. Tried it on an Assembly containing both iParts and iAssemblies and it works well for me:
Class ThisRule
	Dim existingOccs As ComponentOccurrencesEnumerator
	Sub Main
		existingOccs = def.Occurrences.AllReferencedOccurrences(def)
			TraverseAndSetNames(oOcc)
		Next
	End Sub
	Sub RenameExisting(oName As String)
		Dim existingOccWithName As ComponentOccurrence = existingOccs.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = oName)
		If existingOccWithName IsNot Nothing
			existingOccWithName.Name = oName & "_old"
	End Sub
	Sub RenameOcc(oOcc As ComponentOccurrence)
		num += 1
	End Sub
	Sub TraverseAndSetNames(oOcc As ComponentOccurrence)
		RenameExisting(name & num)
		RenameOcc(oOcc)
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject
			For Each sOcc As ComponentOccurrence In oOcc.SubOccurrences
				TraverseAndSetNames(sOcc)
			Next
	End Sub
End Class
 Let me know if it works for you or if I've misunderstood what you're trying to do 🙂
Message 9 of 17
philippe.lagrue
Thanks Jhoel, but this rule fail when it try to rename the iAssembly components :
For information; the link to this assembly is available above: Assembly_02.zip
Message 10 of 17
JhoelForshav
@philippe.lagrue
I managed to change the names in the iAssembly by accessing the factory document of the iAssembly and changing the occurrence name in there. See if this works for you:
Class ThisRule
	Sub Main
		iLogicvb.UpdateWhenDone = True
		Next
	End Sub
	Sub RenameExisting(oName As String, Optional eOccs As ComponentOccurrencesEnumerator = Nothing)
		If eOccs Is Nothing
			existingOccWithName = existingOccs.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = oName)
		Else
			existingOccWithName = eOccs.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = oName)
	End Sub
		num += 1
	End Sub
	Sub TraverseAndSetNames(oOcc As ComponentOccurrence, Optional eOccs As ComponentOccurrencesEnumerator = Nothing)
		RenameExisting(name & num, eOccs)
		RenameOcc(oOcc)
			If oOcc.IsiAssemblyMember
				Dim iAssyMember As iAssemblyMember = oOcc.Definition.iAssemblyMember
				Dim def As AssemblyComponentDefinition = iAssyMember.ReferencedDocumentDescriptor.ReferencedDocument.ComponentDefinition
				For Each sOcc As ComponentOccurrence In def.Occurrences
					TraverseAndSetNames(sOcc, def.Occurrences.AllReferencedOccurrences(def))
				Next
				iAssyMember.ReferencedDocumentDescriptor.ReferencedDocument.Save2(True)
			Else
				Next
	End Sub
End Class
Message 11 of 17
philippe.lagrue
Message 12 of 17
philippe.lagrue
I try now to convert your code to a VBA macro.
I have some difficulties with this line :
Message 13 of 17
JhoelForshav
Hi @philippe.lagrue
VBA doesn't support lambda expressions so we'll have to rewrite the function to instead loop through the ComponentOccurrencesEnumerator to check if there's already an occurrence with the name.
Something like this should work 🙂
Option Explicit
Dim name As String
Dim num As Integer
Sub Main()
    Set def = ThisApplication.ActiveDocument.ComponentDefinition
    Set existingOccs = def.Occurrences.AllReferencedOccurrences(def)
    num = 1
    name = "Part"
    For Each oOcc In def.Occurrences
        TraverseAndSetNames oOcc
    Next oOcc
    def.Document.Update
End Sub
    If eOccs Is Nothing Then
        For Each oOcc In existingOccs
            If oOcc.name = oName Then
                Set existingOccWithName = oOcc
                Exit For
        Next oOcc
    Else
        For Each oOcc In eOccs
                Exit For
        Next oOcc
    If Not existingOccWithName Is Nothing Then
        existingOccWithName.name = oName & "_old"
End Sub
    oOcc.name = name & num
    num = num + 1
End Sub
    RenameExisting name & num, eOccs
    RenameOcc oOcc
    If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        If oOcc.IsiAssemblyMember Then
            Set iAssyMember = oOcc.Definition.iAssemblyMember
            Set def = iAssyMember.ReferencedDocumentDescriptor.ReferencedDocument.ComponentDefinition
            Dim iOcc As ComponentOccurrence
            For Each iOcc In def.Occurrences
                TraverseAndSetNames iOcc, def.Occurrences.AllReferencedOccurrences(def)
            Next iOcc
            iAssyMember.ReferencedDocumentDescriptor.ReferencedDocument.Save2 True
        Else
            Dim sOcc As ComponentOccurrence
            For Each sOcc In oOcc.SubOccurrences
                TraverseAndSetNames sOcc
            Next sOcc
End Sub
Message 14 of 17
GosponZ
  that rule work just perfect like any of yours rules. I do have question:  running this rule in browser tree is changed name but how that name change into part number?
Message 15 of 17
philippe.lagrue
Great , thank you Jhoel.
Message 16 of 17
JhoelForshav
Hi @GosponZ
If I understand correctly, you want to use the part number as the name of each occurrence in the assembly.
Something like this should do the trick 🙂
Class ThisRule
	Sub Main
		Next
	End Sub
		Dim partNum As String = oOcc.Definition.Document.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value
		If oOcc.Parent.Occurrences.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = partNum Or x.Name.StartsWith(partNum & ":")) Is Nothing
			oOcc.Name = partNum
		ElseIf oOcc.Parent.Occurrences.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = partNum AndAlso x IsNot oOcc) Is Nothing
			oOcc.Name = partNum
		Else
			Dim i As Integer = 1
			For Each eOcc As ComponentOccurrence In oOcc.Parent.Occurrences
				If eOcc.Name = partNum Or eOcc.Name.StartsWith(partNum & ":")
					If eOcc IsNot oOcc
						Dim oName As String = partNum & ":" & i
						Dim existingOcc As ComponentOccurrence = oOcc.Parent.Occurrences.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = oName)
						If existingOcc IsNot Nothing Then existingOcc.Name = oName & "_temp"
						eOcc.Name = oName
						i += 1
			Next
			oOcc.Name = partNum & ":" & i
	End Sub
		RenameOcc(oOcc)
				Next
			Else
				Next
	End Sub
End Class
 I had to add numbering to the names if there are multiple occurrences in the same assembly with the same part number. I used a colon as a separator for this (<Part Number>:<Number>). If you use part numbers containing colons maybe use another character for the saparation 🙂
Message 17 of 17
GosponZ
Just opposite.
