Rename sheets based on view labels contained in each sheet
claudio.ibarra
claudio.ibarra
Instead of:
Sheet:1
Sheet:2
Sheet:3.. and so on,
Is it possible to run a rule that renames each sheet based on the View Label names for each view contained in each sheet?
This would make it easier for designers to find section G, or detail B, or detail A3 by looking for those in the sheet model browser sheet names.
So the sheet list could end up looking like:
View1 View30:1
View2 View3:2
A B C:3
D J:4
E F:5
Is that possible with iLogic and Inventor 2020?
JhoelForshav
Hi @claudio.ibarra
Are you looking for something like this? 🙂
For Each oSheet As Sheet In ThisDrawing.Document.Sheets
	Dim oName As String = ""
	For Each oView As DrawingView In oSheet.DrawingViews
		oName = oName & If (oName = "", oView.Name, " " & oView.Name)
	Next
	If oName <> "" Then oSheet.Name = oName
Next
claudio.ibarra
Is it possible to add something that checks for and removes any quotation marks in a detail? Some older drawings used "A" or "A"-"A" instead of just a single letter A for a view label name.
