Rename rule - assembly, subassembly, part and drawing
ralfmja
Message 1 of 22
ralfmja
I ask you in advance not to offer me Vault solutions, ilogic design copy etc. 😀
I will describe my problem below:
When I finish my project (documentation ready) I have to rename files both in terms of models (ipt, iam) and drawings (idw).   I adopted a certain scheme of action and I do it with the help of Design Assistant. Unfortunately, this tool is quite crude and when my project has a lot of elements (e.g. 500) it takes about 3-4 hours.
MODEL BROWSWER AFTER FINISCH DOCUMENTATIONMODEL BROWSWER AFTER FINISCH DOCUMENTATIONFOLDER BROWSWER BEFORE USE DAFOLDER BROWSWER BEFORE USE DADA BEFORE USE DADA BEFORE USE DADA AFTER MANUAL CHANGE NAME & PART NAMEDA AFTER MANUAL CHANGE NAME & PART NAMEFOLDER BROWSWER AFTER USE DAFOLDER BROWSWER AFTER USE DA
short legend:
green dots - items that require changing the part number and file name
pink dot - shopping items - the rule omits them at all
red dot - reference elements - the rule omits them at all
33_33333 - common number for the entire project - I would like to enter it after enabling the rule.
0001 - next part number (ipt file)
B000 - Bxxx - next assy number (iam file)
Of course, the current file names are completely random (for the purposes of the description I named them one after another, i.e.PART1, PART2, SUBASSY etc.)
Unfortunately, I do not have enough programming knowledge but if someone would lead me by the hand - I think I could do it ...
Can anybody help me with that ??
In attachment you can find file which you can see on picture.
Thanks for answer,
ralfmj
Replies (21)
Message 21 of 22
Curtis_Waguespack
@ralfmja wrote:
Hi @Curtis_Waguespack ,
You still haven't found time to look at this ??
Many thanks,
regards,
ralfmj
I actually just forgot about it... the last time I looked at it though it was pretty time intensive as far as testing.... is there anyway you can work with your data set to isolate the issue to a smaller number of files?
Message 22 of 22
ralfmja
Thanks for quick answer @Curtis_Waguespack ,
Unfortunately, I have a problem with isolating elements in such a way that the same problems are revealed as with such a large assembly ...
If you find time, please help ...
Many thanks in advance
ralfmj
