Rename Parts List with iAssembly Member Part Number
dliteful
Message 1 of 9
dliteful
We use iAssembly configurations in one drawing.  I'm hoping to automate the process of renaming the Parts List to reflect the Selected Member BOM.  I found this thread, but it never got around to addressing iAssemblies.  Works perfect otherwise.  https://forums.autodesk.com/t5/inventor-forum/parts-list-title/td-p/2826607/page/2
To keep with our current drawing practices, View1 is always the factory file and View2 is always the member file with the Parts List associated to it.
I attached a PDF of a generic drawing sample.  Any help or insight down the right path would be greatly appreciated.
Replies (8)
Message 2 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@dliteful,
Can you please provide non confidential sample data to test the feasibility?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 9
dliteful
Please see attached.  It's a pretty basic version.  Please let me know if you need more information.  Thank you!
Message 4 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@dliteful,
Actually, code in this forum (https://forums.autodesk.com/t5/inventor-forum/parts-list-title/td-p/2826607/page/2) is iLogic code. Try below VBA code to update title of partslist with part number.
    Sub Partslist()
        'set a reference to the drawing document.
        ' This assumes a drawing document is active.
        Dim oDrawDoc As DrawingDocument
        Set oDrawDoc = ThisApplication.ActiveDocument
        'set a reference to the first parts list on the active sheet.
        'This assumes that a parts list is on the active sheet.
        Dim oPartList As Partslist
        Set oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
        'get the document referenced by the parts list
        Dim oRef As AssemblyDocument
        Set oRef = oPartList.ReferencedDocumentDescriptor.ReferencedDocument
        'set parts list title to be the same as the referenced file's
        'part number iProperty
        oPartList.Title = oRef.PropertySets.Item _
        ("Design Tracking Properties").Item("Part Number").Value
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 9
dliteful
That still renames it to the factory part number which is meant to be generic for all sheets.  I want to rename it to the member part number for each part list.  See attached.  Sometimes images relate info better.
I prefer iLogic if possible.  I was hoping to somehow grab the iAssemblyTableCell.Value
Thank you again for looking at this.
Message 6 of 9
chandra.shekar.g
Autodesk Support
Autodesk Support
@dliteful,
Sorry for delay response,
Try below VBA code which updates partslist name with 2nd view of referenced document's part number.
Sub Partslist()
        Dim oView As DrawingView
        Set oView = oDrawDoc.ActiveSheet.DrawingViews.Item(2)
        Set oRef = oView.ReferencedDocumentDescriptor.ReferencedDocument
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 9
dliteful
Worked perfectly.  Thank you!
Message 8 of 9
dliteful
This works perfect if I run it from each sheet, but I'd like to to cycle through each sheet's parts list.  I can't seem to get the "For Each" statement to look at the correct views.  It just refers to the active sheet I launched the rule from.
Thank you again.
Message 9 of 9
dliteful
With a little tweaking I managed to get it to rename each Parts List after the member.  Here's the code I used if anyone needs.
Sub Main()
    Dim oSheet As Sheet
    For Each oSheet In oDrawDoc.Sheets
        Dim oPartList As PartsList
        For Each oPartList In oSheet.PartsLists
        oView = oSheet.DrawingViews.Item(2)
        Next
    Next
End Sub
