removing special characters
GosponZ
GosponZ
This rule is making browser tree with some properties. It is working perfect if there is no special characters in material or description. My question is how to remove special characters like (, :& ) only from browser tree.
oDoc = ThisDoc.Document
oSheets = oDoc.Sheets
    For Each oSheet In oSheets
        oSheet.activate
        oView = oSheet.DrawingViews.Item(1)
        modelName = oView.ReferencedDocumentDescriptor.ReferencedDocument
        oProp = modelName.PropertySets.Item("Design Tracking Properties")
		'ocProp = modelName.PropertySets.Item("Inventor User Defined Properties") 'Custom property set
        ActiveSheet.Sheet.Name = oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value  '_
		'& " " & "QTY" & " " & ocProp.Item("TTL").Value
    Next
oSheets(1).activate
iLogicVb.UpdateWhenDone = True
tyler.warner
@GosponZ you can try something like this. It is a slight modification to your code. It will not error when it finds a page without a view & it will just remove all characters that are not letters or digits except for spaces.
Dim oDoc As Document = ThisDoc.Document
Dim oSheets As Sheets = oDoc.Sheets
    oSheet.Activate
	Dim oView As DrawingView
	Try
	Catch
		'MessageBox.Show("There is no drawing view on " & oSheet.Name)
		Continue For
	End Try
    Dim modelName As Object = oView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oProp As PropertySet = modelName.PropertySets.Item("Design Tracking Properties")
	Try
		Dim oSheetName As String = oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value  '_
		Dim oDisplayName As String = ""
		For Each letter As Char In oSheetName
			If Char.IsLetterOrDigit(letter) Or Char.IsWhiteSpace(letter) Then
				oDisplayName = oDisplayName & letter
		Next
		ActiveSheet.Sheet.Name = oDisplayName
	Catch
		'MessageBox.Show("Couldn't change sheet name for " & oSheet.Name)
	End Try
Next
oSheets(1).Activate
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Curtis_Waguespack
Hi @GosponZ
You can use Regex for this.
I hope this helps.
Curtis
Imports System.Text.RegularExpressions
        oSheet.activate
		sSpecicals = "[#$%&'()*+,-./\\~:;]"
		oPN = Regex.Replace(oProp.Item("Part Number").Value, sSpecicals, "")
		oDesc = Regex.Replace(oProp.Item("Description").Value , sSpecicals, "")
        ActiveSheet.Sheet.Name = oPN & " " & oDesc
    Next
oSheets(1).activate
GosponZ
Thank you works perfect
GosponZ
thank you it works great
