Removing Characters from Part Number
GosponZ
GosponZ
I posted this question and i got perfect answer. Code is still working but i want to upgrade rule. I wish to remove more then "-" from part number. I need one more character to remove. (".")I beleive it is not to hard . Here is code
If booleanParam = True Then
        Dim PartNumber As String = iProperties.Value("Project", "Part Number")
        iProperties.Value("Custom", "Program") = PartNumber.Replace("-", "")
Else
        booleanParam = False
        iProperties.Value("Custom", "Program") = ""
Thank you
rjay75
Just add the  same type of replacement you have the the "-". You can 'chain' them together.
        iProperties.Value("Custom", "Program") = PartNumber.Replace("-", "").Replace(".","")
Else
GosponZ
i missed dot, .Replace and that is why i had problem.
Again Thank you for help
