Remove Bend Note For High Bend Radius Value
f_yilmaz_82
f_yilmaz_82
Dim oDoc As DrawingDocument
Dim oSheet As Sheet
Dim oView As DrawingView
Dim oCurve As DrawingCurve
Dim oBendNote As BendNote
oDoc = ThisApplication.ActiveDocument
oSheet = oDoc.ActiveSheet
For Each oView In oSheet.DrawingViews
 For Each oCurve In oView.DrawingCurves
  If oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge _
  Or oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendUpEdge Then
	' Create the bend note
	oBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
 Next 'oCurve
Next 'oView
I am using this rule to create bend note.
Is it possible not to create the note if the bend radius value greater than 10mm.
How can i do that
Cadkunde.nl
Well I tried some things with oCurve.
But run into errors all the time.
I am sure this isn't the best solution, and not very proud, but it works and perhaps helps you untill someone has a better solution.
I check the bendnote, for me the text is "DOWN 90,0° R5"
Now what i do is get the position of the last "R" and then take the number behind it.
Then I check if that value is > 10, if so delete it.
Dim oSheet As Sheet
 For Each oCurve As Inventor.DrawingCurve In oView.DrawingCurves
	Dim strNote As String = oBendNote.Text
	Dim pos As Integer = InStrrev(strNote, "R")
	Dim strSize As String = Right(strNote, len(strNote)-pos)
	Dim dblSize As Double = Cdbl(strSize)
	If dblSize > 10 Then
		oBendNote.Delete
 Next 'oCurve
Next 'oView
f_yilmaz_82
Hello.
Thanks so much for your reply. I tried it but unfortunately it doesn't work. It doesn't react.
Cadkunde.nl
If you just copy paste it without reading it, it most likely fails.
My bend note = "DOWN 90,0° R5"
With this code i look for the position of the last "R" then keep everything behind it, so for me it results in "5"
So what does your Bendnote look like?
f_yilmaz_82
This is my bendnote
Cadkunde.nl
Dim oSheet As Sheet
	Dim pos As Integer = InStrRev(strNote, "R")
	Dim strsize As String = Right(strNote, Len(strNote) -pos)
	strsize = strSize.Replace(",", ".")
	Dim dblSize As Double = CDbl(strsize)
	msgbox(strSize & vbLF & dblSize)
		oBendNote.Delete
 Next 'oCurve
Next 'oView
Well I did a check and a bend of 3,05 became value of 305, because it was larger than >10 it got removed
I replace the comma with a dot, and now for me it works
f_yilmaz_82
Ok it is working now. Thank You so much
