I´ve created a VB.NET AddIn that works as intended, but when I manually reload it, I get an unidentified Error.
Public Sub Activate([...])
If firstTime Then
AddToUserInterface()
End Sub
Private Sub AddToUserInterface()
' Get the drawing ribbon.
Dim drawingRibbon As Ribbon = g_inventorApplication.UserInterfaceManager.Ribbons.Item("Drawing")
' Get the "Place Views" tab.
Dim PlaceViewsTab As RibbonTab = drawingRibbon.RibbonTabs.Item("id_TabPlaceViews")
' Create a new panel.
Dim PrintAddInPanel As RibbonPanel = PlaceViewsTab.RibbonPanels.Add("Print Service", "PrintAddInPanel", AddInClientID)
' Add buttons to Ribbon Panel.
PrintAddInPanel.CommandControls.AddButton(m_Print_PDF, False, True)
End Sub
I get the Error the line where I add my custom RibbonPanel.
What code do I need to add to make it work?
Do I need something in the Deactivate() Sub?
Thanks in advance.
