Reg Inventor Addin
Reg Inventor Addin
sundaram1087
Reg Inventor Addin
sundaram1087
Hi
I have created the inventor addin and it loaded successfully when the  assembly files is open.
i had a problem when i opend the part file or drawing files and then come back to the assembly the assembly addin is not  visible to me.
I am able to find the solution for that
Please provide the solution for this
K.Shunmugasundaram
rossano_praderi
Hi Shunmugasundaram,
If I rightly understood your question, your addin will be visible only when you are in an assembly environment.
If I'm in true, you have set the "Behavior" option in your .addin with the value "2".
Is that true?
Can you share more informations about your code?
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
