Reg : Adding Sheets with Part Desciption
naresh_kalyan
naresh_kalyan
Dear all,
My intension is to get a code which can ADD MULTIPLE sheets and correspondingly Prompts the user to enter the PART DESCRIPTION.
Here I have one macro which will give only a INPUT BOX for part Description. But, I dont know where i made wrong.
Its giving only Input Box and later it is not working.
Can anybody help me to make my work so faster and better.
Thanks in advance.
Public Sub AddSheets()
Dim oDoc As Inventor.Document
Set oDoc = ThisApplication.ActiveDocument
' Check the Document type is an assembly or part
If (oDoc.DocumentType <> kDrawingDocumentObject) Then
MsgBox "Error:Document type must be Drawing"
Set oDoc = Nothing
Exit Sub
'Here we will put up a box to ask how many sheets to create
Dim counter, sheet_name, default
default = "PART - 1"
sheet_name = InputBox("Enter Part Description:", "Add Multiple Sheets with Part Description", default)
' user will get a type mismatch error if they enter letters instead of numbers
Call ThisApplication.CommandManager.StartCommand(kCreateNewSheetCommand)
End Sub
I would think that adding sheets would be faster using the following style
of code:
Dim oSheet As Sheet
'take number the user enters and iterate through a loop
For Index = 1 To NumberDesired
Set oSheet = oDrawDoc.Sheets.Add(kDDrawingSheetSize,
kLandscapePageOrientation, _
InputBox("Enter sheet description", "Sheet
Description"))
'add your border definition
Next Index
wrote in message news:5184865@discussion.autodesk.com...
Dear all,
Thanks in advance.
Set oDoc = Nothing
Exit Sub
numbers
End Sub
naresh_kalyan
Thank u Joe for ur response.
Earlier, I got one code which add Sheets as we enter the Number of Sheets.
But, I need to Add Multiple Sheets with their DESCRIPTION.
I am sending the previous code.
Thank you again.
Set oDoc = Nothing
Exit Sub
Dim counter, num_sheets, default
default = "10"
num_sheets = InputBox("Create how many Sheets:", "Add Multiple Sheets", default)
For counter = 1 To num_sheets
Next counter
End Sub
