Reference dimension
Reference dimension
madstrolle
Message 1 of 16
Reference dimension
madstrolle
We often draw square profiles and other parts dimensions that isn't editable. On these profiles we want these dimensions to be, reference dimensions e.g. (50).
Is there a way to do this automatically?
Regards
Replies (15)
Message 2 of 16
CCarreiras
Can you explain better what's your goal?
If you already create the dimensions, You can toggle any ordinary dimension into a reference dimension (and vice-versa)
Select them and click here:
If you are about to create the dimensions, You can turn on the button first and then create the dimensions, the dimensions will be all reference dimensions
CCarreiras
Message 3 of 16
madstrolle
It's when i'm making a 2D drawing. See picture
Message 4 of 16
madstrolle
If I do that way, I can't change the size in my Ilogic form.
Message 5 of 16
Frederick_Law
Maybe use Basic.
If not, set up a Style for Reference Dimension.
Message 6 of 16
madstrolle
Sorry, but it's not working
Message 7 of 16
dimamazutaMMJ32
Hi @madstrolle! Try do use this iLogic rule.
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oDim As Inventor.GeneralDimension
Do
	oDim = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingDimensionFilter, "Select Dimension")
	If oDim Is Nothing
		Exit Do
Dim oDrawingDims As DrawingDimension
For Each oDrawingDims In oDoc.ActiveSheet.DrawingDimensions
oDim.Tolerance.SetToReference
Next
Loop While oDim IsNot Nothing
(view in My Videos)
Message 8 of 16
madstrolle
Not automatic, but it definitely works great, thanks 🙂
Message 9 of 16
dimamazutaMMJ32
Some input information is required to automatically changed specific dimensions. I thought that it is most appropriate to choose the sizes that should be reference dimensions.
If You need to change all dimensions then try this rule
oDrawingDims.Tolerance.SetToReference
Next
Message 10 of 16
madstrolle
I will try it 🙂
But it would be great if it could be done on the actually part. So every time I place the part and call for the dimensions they are with (reference). I'm using ilogic to  generate these hole profiles.
I hope it makes sence.
Message 11 of 16
dimamazutaMMJ32
Please have a look at the standard Inventor command.
However, be careful, for this, the dimensions in the model must be reference, which can lead to accidental changes in these dimensions. A solution may be to impose a lock in the sketch's constrain. Then the dimensions will be references and the lines will not move anywhere. Please check the short video.
(view in My Videos)
Message 12 of 16
madstrolle
But then I can't use ilogic to change the dimensions.
Message 13 of 16
dimamazutaMMJ32
The error occurs because the sketch geometry is locked.
In this case, there is no way to distinguish the normal size from the reference dimensions. If you have two types of dimensions in your drawing, then:
- If most of the dimensions are referenced, use rule 2 and then manually change the necessary sizes to normal dimensions.
- If most dimensions are normal, then use rule 1 and select those dimensions that should be reference.
Message 14 of 16
dimamazutaMMJ32
There is another way if you work with the templates of these profiles and you can add referenced dimensions to them. But these new additional dimensiones must be linked to another geometry.
(view in My Videos)
Message 15 of 16
madstrolle
Thank you.
Together with the rule, this is perfect.
Message 16 of 16
madstrolle
Hi @dimamazutaMMJ32 ,
I'm using this rule all the time, it's working great😊
Would it be possible to change the code, so it also works for "Ordinate Set"?
