ref SAFEARRAY(double)
Message 1 of 13
I have problem understanding how to pass arrays by ref from C#. I will illustrate using Point.GetPointData for simplicity.
The is working:
Point TestPoint = oApp.TransientGeometry.CreatePoint(0, 0, 0);
System.Array pointCoords1 = new double[3];
TestPoint.GetPointData(ref pointCoords1);
This will not compile because pointCoords2 is unassigned.
System.Array pointCoords2;
TestPoint.GetPointData(ref pointCoords2);
This will not compile either:
double[] pointCoords3;
TestPoint.GetPointData(ref pointCoords3);
TestPoint.GetPointData(ref (pointCoords3 as System.Array));
My questions are:
What is the preferred way of doing this?
Say I want to use SurfaceEvaluator.GetParamAtPoint, how do I know the dimension of the solutionNatures[] parameter?
/Johan
Edited by: JohanLarsson on May 5, 2009 10:48 AM
Replies (12)
Message 2 of 13
jeff.pek
Hi Johan -
From a pure C# perspective, this method (and others like it that work with arrays are not optimally defined). For example, they use ref or out when neither is really needed for some parameters, etc.) Let's ignore that as a by-product of the COM interop that's involved.
In general, when working in C# with arrays, you'll need to create an empty array, and then pass that using 'ref' to the method. For example, in this case, I'd bet this will work:
System.Array pointCoords1 = new double[0];
You need to have assigned pointCoords1 to something (to make C# happy), and you need to use 'ref' to make interop happy. This allows a new array to be created during the call, and reassigned to the reference.
Hope this helps.
Jeff
Message 3 of 13
Hi Jeff,
Thank you for your quick answer, much appreciated.
Why doesnt this work:
double[] pointCoords = new double[0];
TestPoint.GetPointData(ref (pointCoords1 as System.Array));
Bear with me, I'm a noob at C#.
/Johan
Message 4 of 13
jeff.pek
Hi again -
That doesn't work because it's not a System.Array that's wanted; it's a ref to an array of doubles. This is similar, if you're familiar with the concept, of passing a pointer to a pointer, so that you can actually change the underlying array object. If you were to look at the objects involved, you actually get back a different one than you pass in.
Jeff
Message 5 of 13
ugh! Does C# not have a "safe" iterable container such as a std::vector?
Message 6 of 13
jeff.pek
Sure it does. It has several, in fact.
Array itself is easily iterable using foreach().
The trick here is the fact that we need to go through COM to get arrays to/from the Inventor API, which doesn't know anything about .NET's types. The array concept is one that the COM interop layers know how to marshal, so it's relatively straightforward, except for the need to create something that really never has a purpose.
Not quite sure what you're getting at.
Jeff
Message 7 of 13
"get arrays to/from the Inventor API, which doesn't know anything about .NET's types"
ah, thats the catch. I am just used to seeing std C++ like:
typedef std::vector<double> myvector;
void foo(myvector& v)
// do something
void bar()
myvector v; // create the vector
// add some elements
foo(v); // call the function
almost totally safe (if std::vector is implemented correctly), pass by reference, clean-ish syntax, no need to "new" anything, also no need to worry about vector length or how to grow/shrink the vector.
"Not quite sure what you're getting at."
I just figured with the new push towards .NET, that the application programmer could use some more sophisticated containers and not have to go so close to the metal. I've never worked with .NET, so I was just surprised to see the "new" and "ref" keywords. Not criticizing, just an observation.
Message 8 of 13
C# intellisense tells me that a System.Array is wanted.
This will not compile.
NominalPoint.GetPointData(ref pointCoords);
Message 9 of 13
jeff.pek
Hi -
The same thing does work for me:
Inventor.Point pt = massProps.CenterOfMass;
double[] pointData = new double[] { pt_x, pt_y, pt_z };
pt.PutPointData( ref pointData );
double[] pointDataOut = new double[0];
pt.GetPointData(ref pointDataOut);
What error are you getting?
Jeff
Message 10 of 13
I'm using Inventor 2008 & Visual studio 2008.
Will not compile fo me:
Error 1 The best overloaded method match for 'Inventor.Point.GetPointData(ref System.Array)' has some invalid arguments.
Error 2 Argument '1': cannot convert from 'ref double[]' to 'ref System.Array'
/Johan
Message 11 of 13
jeff.pek
Oh... Inventor 2008...
That uses a different mechanism (imported type library) to define the Inventor API. It must have defined that parameter as a System.Array.
Try using Array.CreateInstance:
Array pointData = Array.CreateInstance(typeof(double), 0);
pt.GetPointData(ref pointData);
- Jeff
Message 12 of 13
jeff.pek
- Jeff
Message 13 of 13
Hello
This works fine:
On the ugly side though.
Thanks for your help.
