ReDim an Array Problems
I'm trying to Redim an array.
I first define it as
dim arProps() as string
later in the code I redim it as
ReDim Preserve arProps(0 To ListBox1.ListCount, 0 To 1)
where ListBox1.Listcount is usually around 25 to 35
however I only end up putting in one row of info
now later in the code I want to strip out the extra blank cells so I redim
to
ReDim Preserve arProps(0 To EmptyArraySpot, 0 To 1)
where the first time around EmptyArraySpot is 0
this is where the error occurs
I'm assuming arProps(0 to 0, 0 to 1) is illegal but why? It's simply a one
row, two column array...
ReDim Preserve arProps(EmptyArraySpot, 0 To 1) gives the same error
(subscript out of range)
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
Try switching the columns and rows. You can only change the last number in
the array.
From Help
"If you use the Preserve keyword, you can resize only the last array
dimension and you can't change the number of dimensions at all. For example,
if your array has only one dimension, you can resize that dimension because
it is the last and only dimension. However, if your array has two or more
dimensions, you can change the size of only the last dimension and still
preserve the contents of the array. The following example shows how you can
increase the size of the last dimension of a dynamic array without erasing
any existing data contained in the array.
ReDim X(10, 10, 10)
ReDim Preserve X(10, 10, 15)"Kathy Johnson
OK I guess I missed that part in the help (it was late last night).
Well that stinks. I don't see why you shouldn't be allowed to resize the
first dimension...
Guess I'll have to do some array trickery...
Thanks Kathy..
Sean Dotson, PE
"...and quit driving 50MPH in the left lane!!!"
"..and quit driving in the left hand lne at 50 MPH!!"
"KJohnson" wrote in message
news:584E3AE907EDB54053EA5476603833D0@in.WebX.maYIadrTaRb...
in
> the array.
> From Help
example,
because
can
> ReDim X(10, 10, 10)
No problem. I hope it clears up your error.
Kathy Johnson
Sean,
I have done the following in AutoCAD and it works fine
Dim mstrLayerNameArray() As String
'redimension array to hold states of all layers
ReDim mstrLayerNameArray(ThisDrawing.Layers.Count - 1, 6)
The first dimension designates the rows and the second is columns. Now I have re-dimensioned the columns in this example but I don't think once you have set it for the first time that you can change it after that.
HTH
Joe
Right... the problem is I already had it dimensioned...I figured out a way
around it however. Thanks.
Sean Dotson, PE
"joesu" wrote in message
news:f16f0a9.3@WebX.maYIadrTaRb...
> Sean,
> Dim mstrLayerNameArray() As String 'redimension array to hold states of
all layers
> HTH
> Joe
