Redefine sketch in assembly
Skadborg.NTI
Message 1 of 1
Skadborg.NTI
I can redefine sketch plane and origin in a partdocument with this code:
Dim oCompDef= ThisApplication.ActiveDocument.ComponentDefinition
Dim oSketch As PlanarSketch = oCompDef.Sketches.Item(1)
oSketch.PlanarEntity = oCompDef.WorkPlanes.Item(2)
oSketch.OriginPoint = oCompDef.WorkPoints.Item(1)
But in an assemblydocument I can only set PlanarEtity. It fails when I try to set OriginPoint ("The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))")
Is there a way around this problem?
Replies (0)
