Rectangular pattern with assigned edge
NachoShaw
Advisor Advisor
NachoShaw
Hey
I have some code together that can pattern along an axis but i dont need an axis, i need an edge that i have assigned a name to. I can get the edge but i keep getting an error 'Parameter is incorrect'.
I have tried assigned the edge as an edge and also as an object but both give me the same error. what can i do to successfully use the edge with an assigned name as a pattern in my assembly? I dont want to use an axis because the pattern direction is driven by the angle of the edge on the component.
My code-
Dim DocToPattern As ComponentOccurrence = ADef.Occurrences.Item(1)
Dim PatternName As String = "MyPattern"
Dim addin As ApplicationAddIn = My.Application.G._Invapp.ApplicationAddIns.ItemById("{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}")
Dim iLogicAuto As Object = addin.Automation
Dim namedEntities As Object = iLogicAuto.GetNamedEntities(_BMDoc)
Dim oEdge As Edge = namedEntities.FindEntity("PatternEdge")
Dim oParentOccs As ObjectCollection = My.Application.G._Invapp.TransientObjects.CreateObjectCollection
oParentOccs.Add(DocToPattern)
Dim oRectOccPattern As RectangularOccurrencePattern = _ADef.OccurrencePatterns.AddRectangularPattern(oParentOccs, oEdge, True, Spacing, PatternName)
If i replace oEdge with this, it works ok
Dim oXAxis As WorkAxis = _ADef.WorkAxes.Item(1)
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
Update:
i noticed i had not added in the Pattern Qty in the code example
Dim oRectOccPattern As RectangularOccurrencePattern = _ADef.OccurrencePatterns.AddRectangularPattern(oParentOccs, oEdge, True, Spacing, Qty, PatternName)
Nacho
