I have the code below. This code is to check for Hole features in a part.
If I have a pattern of a Solid Body then the code gives an error on the following line (if I have a pattern of any feature the code works fine):
If (TypeOf oRPF.ParentFeatures.Item(1) Is HoleFeature) Then
How can I check to see if I have a pattern of a Solid Body?
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oRectPatterns As RectangularPatternFeatures
Set oRectPatterns = oDef.Features.RectangularPatternFeatures
Dim oRPF As RectangularPatternFeature
For Each oRPF In oRectPatterns
If Not oRPF.Suppressed Then
‘do something
Next
