Recognize if a derived part link has been broken.
shastu
Advisor Advisor
shastu
I have some vba code that looks at an IPT file and checks if it came from a derived part of iam file.  So in other words if oSubs1.Count = 1 then it is from a derived part or assembly and then if that is the case things are handled differently than if it just a regular part.  However, if it is a derived assembly or part that the link has been broken, then I want it to use the same logic as if it was just a regular part and not a derived part.  Unfortunately, even though the link was broke, the oSubs1.Count is still = 1.  Is there anything I can use to recognize that the link has been broke?
Shawn
JamieVJohnson2
Have a look at this:
DerivedFutureAssemblyComponent.SuppressLinkToFile Property
It also exists in:
DerivedAssemblyComponent.SuppressLinkToFile Property
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
shastu
Thanks for pointing me in the right direction.  I think what will work for my application is the below:
    For Each derived_assy In part_doc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents
        If derived_assy.LinkedToFile Then
