Reading Excel or text file to fill some iproperties
info
info
I'm looking for an Ilogic rule which does the following:
1)Reading Excel file in C\temp (is .txt. faster?)
2)Fill some iProperties values in .iam and .ipt. like Engineer,  Checked By, Project, Company
I have a rule which runs a few other rules when it is a part or assembly.
So my wish is to add this new rule to the existing
Who is able to help me?
A.Acheson
It looks like these iProperties you want to enter are a small number and will likely not change much. You can build these in to an external rule using an arraylist of strings and select them by a Input list box and input box. No need for excel unless you have this information all ready prepopulated in some control document you are using. Can you tell us how you will be interacting with this information? Are you looking for individual entry on each document or looking to use static information to fill out multiple documents?
External Rule
 Dim oEngineer, oCheckedBy, oProject, oCompany As String
'[ Engineer
 Dim Engineers As New ArrayList
 Engineers.Add("David")
 Engineers.Add("Mark")
 Engineers.Add("Cassandra")
 oEngineer = InputListBox("Pick One", Engineers, d0, Title := "iProperties", ListName := "Engineer List")
 iProperties.Value("Project", "Engineer")= oEngineer
'[ Checkers
 Dim Checkers As New ArrayList
 Checkers.Add("DA")
 Checkers.Add("AD")
 Checkers.Add("FD")
 oCheckedBy = InputListBox("Pick One", Checkers, d0, Title := "iProperties", ListName := "Checked By List")
 iProperties.Value("Status", "Checked By") = oCheckedBy
 '[ Companies
 Dim Companies As New ArrayList
 Companies.Add("DADDT")
 Companies.Add("Icescream")
 Companies.Add("Dirt Removal")
 oCompany = InputListBox("Pick One", Companies, d0, Title := "iProperties", ListName := "Companies List")
 iProperties.Value("Summary", "Company") = oCompany
oProject = InputBox("Prompt", "Project Name", "Enter Project Name here")
iProperties.Value("Project", "Project") = oProject
For multiple document using static information from excel sheet use the below rule
iProperties.Value("Project", "Engineer") = GoExcel.CellValue("filename.xls", "Sheet1", "A2")'Enter File path
iProperties.Value("Status", "Checked By") = GoExcel.CellValue("filename.xls", "Sheet1", "B2")'Enter File path
iProperties.Value("Summary", "Company") = GoExcel.CellValue("filename.xls", "Sheet1", "C2")'Enter File path
iProperties.Value("Project", "Project") = GoExcel.CellValue("filename.xls", "Sheet1", "D2")'Enter File path
 Find the excel snippets here
A text file may be faster but formatting and reading the file via code  is harder to set up and may not be user friendly at dealing with lists etc.
Regards
Alan
