Read Part List from an Assembly and create corresponding sheets for each part with base view and parts list sorted
G.Binl
G.Binl
This is a larger order I'm sure I have a few pieces of the puzzle but would like to place them all into one rule or blocks of rules.
I have some rules that allow me to do items 3, 4, & 5 on an established drawing package.
I can do single sheet and multi sheets with Items 3,4 & 5 all of which are separate rules with a few nuances but work.
I would like to read this Parts List that’s on a cover sheet.
  1. Start a new Drawing or Sheet to this drawing that it read from.
  2. Navigate to file (101 – Supply from tank) and add a Base view with top, side view and isometric.
  3. Add Parts List for the Base view place at top of drawing.
  4. Sort Parts list.
  5. Add Rev Block at a certain location
  6. Add Third angle sketch that lives in our Sketch symbols as ( Projection – Third Angle )
  7. Next
  8.
Folders and assemblies are consistent as seen in A and A1
Any Help would be great thanks all
A.Acheson
This looks like a ilogic/vba automation request. So will need to be moved by the moderator to the programming forum. @johnsonshiue could you take care of this move when you have a chance?
Can you supply the rules you are looking to integrate? This will help cut down on the amount of work required to help you and also see how you want this constructed.
  1. Questions are the views to be added are they contained in a sheet set or to be on the fly generated views?
  2. Is the model/folder reference in the part number actually linked to an assembly or is it just text?
Some links from the API help are below, they may help you get further. I would supply just work with a String file path so you can get the drawing creating functioning then integrate in the retrieval of the string later.
Parts list query
Add sheet set containing views
Adding symbols
Regards
Alan
G.Binl
Thanks for the feed back.
I'm using this for adding parts list:
'Need to add a sorting function
iLogicVb.UpdateWhenDone = True
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'Set a reference to the active sheet.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
' Set a reference to the first drawing view on
' the sheet. This assumes the first drawing
' view on the sheet is not a draft view.
Dim oDrawingView As DrawingView
Try
	oDrawingView = oSheet.DrawingViews(1)
Catch
	MessageBox.Show("No View found. Can not continue", "iLogic")
	Return 'return exits the rule
End Try
' Set a reference to th sheet's border
Dim oBorder As Border
oBorder = oSheet.Border
Dim oPlacementPoint As Point2d
If Not oBorder Is Nothing Then
    ' A border exists. The placement point
	' is the top-right corner of the border.
	oPlacementPoint = oBorder.RangeBox.MaxPoint
Else
    ' There is no border
	oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(20, 20)
Dim oPartslist As PartsList
Try
	'look for the first parts list found on the sheet
	'if succesful finding it,
	'tell the user,then Do Nothing
	oPartslist = oSheet.PartsLists(1)
	MessageBox.Show("There is an existing Parts List", "iLogic")
Catch
	'if one is not found, Create it
	oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
End Try
Im useing this for sorting the parts list.
Dim oPartsList1 As PartsList
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
oPartsList1.Sort("ASME BPE", 0, "SIZE", 0, "QUANTITY", 0)
and this for the REV block placement:
Sub Main RemoveAllTags()
	Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
	For Each oSheet In oDrawDoc.Sheets
		oSheet.activate
		ProcessSheet(oSheet)
	Next
	oDrawDoc.Update
End Sub
Sub ProcessSheet(oSheet As Sheet)
	If oSheet.RevisionTables.Count = 0 Then
		On Error Resume Next
	Dim oRTB As RevisionTable = oSheet.RevisionTables.Item(1)
	Dim oRows As RevisionTableRows = oRTB.RevisionTableRows
	oRows.Add()
	Dim oRow As RevisionTableRow = oRTB.RevisionTableRows.Item(oRTB.RevisionTableRows.Count)
	For Each oRow In oRows
		If oRow.IsActiveRow Then
		Else
			oRow.Delete
	Next
oRTB.Delete
Dim oRTBs As RevisionTables
oRTBs = oDrawDoc.ActiveSheet.RevisionTables
Dim oLocation As Point2d
oLocation = ThisApplication.TransientGeometry.CreatePoint2d(68.08999997, 9.780835)
oRTB = oRTBs.Add(oLocation)
End Sub
hope this helps
G.Binl
oops sorry i did not answer your questions
1. Views would be fly generated, because there is always different scaling which would be done manually when the drawing gets detailed.
2. The Texted name is the model name as seen in A1.
A.Acheson
If I was building this I would likely set it up with sub routines for each operation, it is easier to digest and also they are good for use in other projects also. You could start with the layout sub routine inside sub main where your bullet points can serve as the action plan to launch each stage. If there is common objects between all of the sub routines then declare and set them in Sub Main then pass them to each sub routine that needs them. This leads to easier controlled objects. Even if you establish a calling sub routine and in  the sub routine is a message box then that would be a good starting point.
Sub Main
  4. Sort Parts list.
End Sub
Here is a link to adding a Base view to a sheet. Once you have that in then you can start trying to position each view and add additional views. Sheet sets is easier as all the views are layed out in advance.
If you have more specific question please ask away.
Regards
Alan
G.Binl
@A.Acheson
Thanks for the Advice I was thinking the same thing keeping separate Rules and step through
a sequence of events.
