read out scaling factor of model via VBA
luis-antonio.fonseca-duarte
Hello all,
we use the derivative to represent the dimensions before and after shrinkage on drawings. We want to write both dimensions on the drawing and display them visually different. I have already implemented this via VBA by a manual query of the factor. Since this factor has already been entered in the model via the scaling factor, I would like to read it out to have the same value. How can this value be read out? I am not that skilled in VBA yet, maybe someone can give me a hint.
Thanks.
A.Acheson
Can you please provide the code you are using in VBA along with some images of your intended workflow? If you have a sample non confidential data set please attach as this will help with testing. What Inventor version are you using?
Regards
Alan
