Read Only
Read Only
andrew_canfield
Read Only
andrew_canfield
To investigate problems I pack & go to the 😧 drive.
When making edits I get a, file is 'read only' message - the pack & go is from a data management system.
I think that might leave it's 'read only' setting in the files.
How could I force them to be read write?
Andrew
MechMachineMan
This would either be an issue regarding the file set to Read-Only through the windows properties,
OR an issue of you using an incorrect project file that references parts you want to edit as being in a library location.
If you can right click the file and in the properties it doesn't say read only, you likely need to brush up on your understanding of project files.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
andrew_canfield
right click & remove the read only attribute before inventor is open appears to have worked.
