read only mode fix
read only mode fix
JfoxQFYKA
read only mode fix
JfoxQFYKA
Is there a way to disable this at all? If I use vault and view older versions "read only" is just fine and if the option was a selection to pick instead of telling Inventor 15 times that 'no, I don't want to check this out'
Anyway, after I view an older version from Vault, everything thereafter will open in read only until I close down Inventor and restart it. That's ridiculous
Darkforce_the_ilogic_guy
Inventor uses read only form windows .. can´t you just remove the read only in windows without closing inventor? Do not know if it will work for you in this cause … but know it will work in other…
