Read all Properties from referenced drawings
GeorgK
Advisor Advisor
GeorgK
Hello together,
whats the best and quickest way to iterate through a complete assembly and read all Part Number from all refenced drawings? I would like to compare the number from the part with number of the drawing and update it if it´s not correct.
For Each docFile In openDoc.AllReferencedDocuments
  Dim oIProInEachRefDoc
  oIProInEachRefDoc = docFile.PropertySets("Design Tracking Properties").Item("Part Number")
  Dim oPartNo
  oPartNo = oIProInEachRefDoc.Value
  MessageBox.Show(oPartNo)
Next
Thank you Georg
GeorgK
Solved it.
adam.nagy
Autodesk Support
Autodesk Support
Hi Gerg,
I'm glad you managed to find the solution.
Could you please write it down here and then set it as the accepted solution?
Thank you,
Adam Nagy
Autodesk Platform Services
