Re-Attach Annotation
Hello, I'm trying to solve a problem Ive got with reattaching Leader Text, Balloons and Sketched Symbols with Leaders. If a part in a assembly is suppressed and then unsuppressed the Annotations fall off. I have created a rule to reattach all the Leader Text Annotations but a cant find the code to identify the if the leader text or the leader is unattached, if you look at the attached example for reattaching dimensions within the code.
' Add each un-attached dimension to the select set.
Dim oDrawDim As DrawingDimension
'iterate each dimension
For Each oDrawDim In oDrawDoc.ActiveSheet.DrawingDimensions
'if it is orphaned
If Not oDrawDim.Attached Then
' set the layer to the dummy layer
oSelectset.Select(oDrawDim)
The (.Attached) identifies if the dimension is attached or Un-attached
Public Class Drawing
    Private Com As New Common
    Private oApp As Inventor.Application
    Public Sub ReatachDimensions()
        MsgBox("ReatachDimensions Is Running")
        ' Get the active document, assuming it is a drawing.
        Dim oDrawDoc As DrawingDocument
        oDrawDoc = oApp.ActiveDocument
        MsgBox(oDrawDoc.DisplayName)
        ' Get the collection of dimensions on the active sheet.
        Dim oDimensions As DrawingDimensions
        oDimensions = oDrawDoc.ActiveSheet.DrawingDimensions
        ' Get a reference to the select set and clear it.
        Dim oSelectset As SelectSet
        oSelectset = oDrawDoc.SelectSet
        oSelectset.Clear()
            'if it is orphaned
                ' Get the CommandManager object.
                Dim oCommandMgr As CommandManager
                oCommandMgr = oApp.CommandManager
                ' Get control definition for the arrange dimensions command.
                Dim oControlDef As ControlDefinition
                oControlDef = oCommandMgr.ControlDefinitions.Item("DLxAnnoReconnectCmd")
                ' Execute the command.
                Call oControlDef.Execute()
                oSelectset.Clear()
                'Call Run_CMD("DLxAutoReattachSickAnnotationsCmd")
        Next
    End Sub
And this is the code for Reattaching the Leader Text, as you can see it does'nt identify if any of the Leaders that are unattached. i suspect its got something to do with the Leaders for all the Leader Text, Balloons and Sketched Symbols. But i reallly need be able to differenciate between Attached and Un-attached.
 Public Sub Reatachleader()
        MsgBox("Reatachleader Is Running")
        Dim oDrawDoc As DrawingDocument = oApp.ActiveDocument
        Dim oSheet As Sheet = oDrawDoc.ActiveSheet
        'This Drawing Document Select Set
        Dim oSelectset As SelectSet = oDrawDoc.SelectSet
        oSelectset.Clear()
        Dim oLeaderNotes As LeaderNotes = oSheet.DrawingNotes.LeaderNotes
        For Each oLeaderNote As Inventor.LeaderNote In oLeaderNotes
            oSelectset.Select(oLeaderNote)
            '------------------- Do Somthing ------------------------
            oControlDef = oCommandMgr.ControlDefinitions.Item("DLxAutoReattachSickAnnotationsCmd")
            'Call Run_CMD("DLxAnnoReconnectCmd")
            '------------------- End Doing Somthing -----------------
            oSelectset.Clear()
        Next
    End Sub
I would appreciate any help i can get with this.
Thanks In advance.
Paul H
adam.nagy
Autodesk Support
Autodesk Support
Hi Paul,
You could check the leader nodes:
  Dim lt As LeaderNote
  Set lt = ThisApplication.ActiveDocument.SelectSet(1)
  Dim nodes As LeaderNodesEnumerator
  Set nodes = lt.Leader.AllNodes
  Call MsgBox(nodes(nodes.count).AttachedEntity Is Nothing)
Cheers,
Adam Nagy
Autodesk Platform Services
rschader
I have a related problem that I've been dealing with maually for quite some time, and would like to make my job easier. I currently have a macro I wroote a few years back that adds a leadernote to a centermark on included points in a part in an assembly to place an indentifying tag for the point (with or without XYZ coordinates) on the drawing, and it works quite well. However, whenever I have to revise the assembly with a new part, and I derive the workpoints into the new part, I currently have to open the drawing with updates deferred, then manually drag all those leader connections away from the original points, then update the drawing, go through and include the new points and then re-attach the leadernotes manually. Otherwise, even though preserve annotations is turned on, those leadernotes just disappear entirely when opening the drawing without deferring updates (which has been an ongoing issue as long as I have used Inventor, going on 15 years!).
Since these leadernotes are kind of "sticky" to the centermark they are attached to (you have to drage the leader away far enough to break the connection), I'd like to be able to write a macro where I could just click on the leader and dis-associate it to the centermark without having to drag it. Any ideas?
TIA, Bob
