Radio Button Group Sizing
brad.jackson
brad.jackson
I am having an issue with the group / boundary sizing when I use radio buttons.  The issue is not consistent.  I would think that the boundary box would automatically size to fit the number of radio buttons but one of my parameters ROOM TYPE gives me a boundary box height that is clearly too tall for the number of radio buttons.
You can see that the boundary for the DOOR TYPE is sized correctly.  Both parameters have a column count of (2).
petr.meduna
brad.jackson
That works.  Any idea why the empty space is needed to fix this or what the root cause is.  I notice that when I created a new form in the same .iam and used the same parameter, it worked as I would expect without using the empty space.
petr.meduna
You can also set height of the parameter in 'Size Limits' instead of using Empty Space. It happen because radiobuttons are sizeable and when there is no limits, parameter just fill whole space of the form control.
