"Save Run Macro" Questions
isocam
isocam
Can anybody help???
I have been using the addin "Save Run Macro" to automatically run a macro every time the "Save" button is pressed.
Does anybody know the answers to any of the following questions about "Save Run Macro"?
1]
When I protect the macro from viewing (so I can protect my code) "Save Run Macro" does not see the macro.
Does anybody know a fix?
2]
When I save the part for the first time (ipt, iam or idw/dwg) the macro does not run. I always need to run the macro again. Does anybody know a fix?
Many thanks in advance!!!!
philippe.leefsma
Hi There,
Sorry but I'm not aware of the "Save Run Macro" add-in. Is it a native Inventor or Autodesk add-in?
If not, then you should seek support with that add-in authors directly.
Thank you,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
