"GoExcel.FindRow" not returning error when the values are not matching the excel values
hamzabuttX6GV8
hamzabuttX6GV8
I use an excel file to pass model parameters. I use the following command to get the exact row:
GoExcel.FindRow("TEST.xlsx", "Sheet1", "BORE", "=", BORE, "FLANGE_OD", "=", FLANGE_DIA, "COOLING_DISK", "=", COOLING_DISK)
 The problem is that when I enter the wrong value of "BORE", it surprisingly doesn't return an error and continues to generate the model. The "BORE" value that I enter is not present in the excel sheet so how does it know which row to go to.
tyler.warner
You can find a related post where @WCrihfield shows some checking for a similar situation here.
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
hamzabuttX6GV8
Thank you! This helped me figure it out.
