quickly rename parts and assemblies to new job number
slphantom
slphantom
I am wondering if there is a way to quickly update our job numbers on details and assemblies when copying
them over to a new job. It takes a lot of time in Design Assistant. The details are usually similar but always different.
Checked out Design Cloner but I am wondering if there is an app or Ilogic program that could do a whole directory at once?
I am not good at Ilogic so how hard would this be to do?
Our job numbers on detail and assemblies are as follows:
1234 will be the number that changes.
DETAILS---- J-1234-D05678_DETAIL NAME.IPT
DETAILS SUCH AS IN WELMENT COMPONENTS---- J-1234-D05678A_DETAIL NAME.IPT
SUB ASSEMBLIES---- J-1234-U05670_SUB ASSY NAME.IAM
MAIN ASSEMBLIES---- J-1234-L05670_MAIN ASS NAME.IAM
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
firelinsgs
if i understood that correctly. You want to replace specific numbers in names of parts?
MAIN ASSEMBLIES---- J-1234-L05670_MAIN ASS NAME.IAM >>> MAIN ASSEMBLIES---- J-6789-L05670_MAIN ASS NAME.IAM  ???
So I think you answered yourself. Design cloner can do that a whole directory at once.
JamieVJohnson2
highly detailed pseudo code (that means not tested or spell checked) I write in vb.net, but this should also work in iLogic, but VBA will need modifications:
public property invApp as inventor.application
public sub copyInventorFilesFromDirectory(strDirectoryIn as string, strDirectoryOut as string)
invapp = GetInventorApplication 'this my custom routine for vb.net, for ilogic you can use = thisapplication
dim diOriginal as directoryInfo = new system.io.directoryinfo(strDirectoryIn )
dim diNew as directoryInfo = system.io.CreateDirectory(strDirectoryOut )
for each fi as fileinfo in dioriginal.enumeratefiles
select case fi.extension
case is "iam"
copydoc(fi)
case is "ipt"
copydoc(fi)
end select
next
public function copydoc(fi, diNew) as inventor.document
dim newFilename as string = getnewfilename(fi, diNew)
dim fiNew as new fileinfo = fi.copyto(diNew.fullname & "\" & newfilename)
dim invDoc as inventor.document =invapp.Documents.open(fiNew) '.OpenWithOptions has many more features to help
control opening issues.
Dim props As Inventor.PropertySet = invDoc.PropertySets.Item(Tools.DesignTrackingPropertySetID)
Dim prPartNumber As Inventor.Property = props.Item("Part Number")
dim newPartNumber as string =  System.IO.Path.GetFileNameWithoutExtension(fiNew.Name)
prPartNumber.Value = newPartNumber 'construct this from file name, or get filename from this
invdoc.save
return invDoc
end function
public function GetNewFileName(fi, dinew)
'do the work to convert the old file name to the new file name using the new directory path, then return as string value of full file path (drive:\folders\file.extension)
return strNewFileName
end function
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
