Quick Ilogic question
Message 1 of 11
Hi i'm not very well versed in ilogic so i found a script on the forum to do exactly what i'd like to do. The only issue is i need it to check both that the feature is a hole and that it is a certain diameter. I'd like to change the line below so I can and diameter condition.
If TypeOf oFeature Is HoleFeature Then
I'd like to add an additional condition here to only preform the next statement if the hole is let's say .125 diameter.  I'm assuming this isn't very difficult but I'm very new to this. Any help would be greatly appreciated. Thanks!
Replies (10)
Message 2 of 11
jholland3XDLM
you can use the word And
for example
If TypeOf oFeature Is HoleFeature And holeDiameter = 0.125 Then
I am assuming a  parameter for the diameter of the hole is named holeDiameter, you could use d120 or whatever the parameter name is. If it is a valid parameter name it should turn blue in the iLogic browser.
Message 3 of 11
AdamAG99T
Once you determine that the oFeature is a hole then you should be able to get the value from oFeature.HoleDiameter. Putting them both in the same If statement would work but could throw some errors on non-hole features, so this is likely the simplest method.
If oFeature.HoleDiameter=.125 Then
'Code here
Message 4 of 11
Thanks for your help
I added the code as you said but i'm getting an error. It says overload resolution failed because no public '=' can be called with these arguments. 'Public Shared Operator =(left as double, right as foublte) as Boolean': Argument matching parameter 'left; cannot convert from '_ComObject' to 'Double'.
Any help would be greatly appreciated!
Message 5 of 11
AdamAG99T
My apologies, I forgot you need to add .Value to the end of the HoleDiameter. Also of note is the fact that inventor uses cm for all of it's internal value storage so make sure you convert your measurements appropriately.
If oFeature.HoleDiameter.Value=.3175 Then '.3175cm=.125in
'Code here
Message 6 of 11
jholland3XDLM
Separating into two If statements is a good idea.
I did not know that a variable could be associated to a Feature like Adam suggested and I would like more information on that. In the meantime, I would just remove the "oFeature." part of the second if statement. It is already only going to check the holeDiameter when oFeature is a HoleFeature.
So as long as that parameter is present and set to something every time that oFeature is a HoleFeature then you are ok. If there are instances where holeDiameter is not present or is set to something other than a number then you will need to add additional code to figure that out.
Message 7 of 11
AdamAG99T
I'm assuming this code runs through every feature in the part file, so the oFeature is needed in the 2nd if statement to point the HoleDiameter.Value to the specific HoleFeature and it's associated information. oFeature.HoleDiameter specifically pulls the associated parameter controlling the diameter of the hole feature that oFeature is referring to at that present moment in the code, regardless of what that parameter is actually named.
Since you mentioned wanting to know more information on this, I mainly refer to the Inventor API documentation found here as well as looking up various VBA tutorials and documentation if I have a general programming issue
Message 8 of 11
jholland3XDLM
So it accesses the hole diameter in that feature, not the parameter that was entered. I could name that specific hole as flangeHole and the Diameter as flangeBoltHoleDia but the syntax  oFeature.HoleDiameter.Value will still change the hole diameter even though I renamed the parameter?
When accessing it this way, the fact that it sees everything as cm becomes important. If i accessed the parameter directly it wouldn't matter. Then of course I would need the specific name of the parameter, eliminating the ability to loop thru all features.
I still have a lot to learn!
Message 9 of 11
AdamAG99T
Yes, the benefit of accessing the parameter without explicitly referring to it by name is that you can access it from a loop or other more broad application. This is likely not the most efficient or cleanest way to do so but as a quick example showing how this would be used I made a rough example.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument  'gets the active file
Dim oCompDef As PartComponentDefinition = oDoc.ComponentDefinition 'provides access to the various features of the part file
Dim oPartFeatures As PartFeatures = oCompDef.Features 'a collection of every feature in the specified part file
For Each oFeature In oPartFeatures 'runs through every feature in the part file
 If TypeOf oFeature Is HoleFeature Then 'checks if the feature is a hole
   MessageBox.Show(oFeature.Name) 'prints the name of the hole feature when it has a diameter of .125 in
End If Next
Message 10 of 11
Hey probably just something silly but I'm still getting an error.
It says "Object variable or With block variable not set."
I'll paste my full code below I'm guessing I don't have the features defined correctly. Thanks!
Sub Main
	Dim oDoc As DrawingDocument
	Dim oSheet As Sheet
	Dim oViews As DrawingViews
	Dim oView As DrawingView
	' Get the active drawing document.
	oDoc = ThisApplication.ActiveDocument
	'call the sub to create layer
	Call CreateLayer
	'get current sheet so it can
	'be made active again later
	Dim oCurrentSheet As Sheet
	oCurrentSheet = oDoc.ActiveSheet
	' Iterate through the sheets
	For Each oSheet In oDoc.Sheets
	'	activate the sheet
		oSheet.Activate
		' Iterate through the views on the sheet
		For Each oView In oSheet.DrawingViews
			Dim docDesc As DocumentDescriptor
			docDesc = oView.ReferencedDocumentDescriptor
			' Verify that the drawing view is of part
			If docDesc.ReferencedDocumentType <> kPartDocumentObject Then
				Continue For
			' Get the component definition
			oCompDef = docDesc.ReferencedDocument.ComponentDefinition
			' Process the view, wrapping it in a transaction so the
			' each view can be undone with a single undo operation.
			Dim trans As Transaction
			trans = ThisApplication.TransactionManager.StartTransaction( _
									oDoc, "Change drawing view color")
			' Call the sub to change colors
			Call ProcessColor(oView, oCompDef)
			trans.End
		Next
		'update the sheet
		oSheet.Update
	Next
	'return to original sheet
	oCurrentSheet.Activate
End Sub
Private Sub ProcessColor(drawView As DrawingView, _
                                oCompDef As ComponentDefinition)
   	' Iterate through features
   	Dim occ As ComponentOccurrence
	For Each oFeature In oCompDef.Features
			If oFeature.HoleDiameter.Value = 0.65278 Then
			' Get all of the curves associated with the feature
			On Error Resume Next
			Dim drawcurves As DrawingCurvesEnumerator
			'drawcurves = drawView.DrawingCurves(occ)
			drawcurves = drawView.DrawingCurves(oFeature)
			If Err.Number = 0 Then
				On Error GoTo 0
				' Create an empty collection.
				Dim objColl As ObjectCollection
				objColl = ThisApplication.TransientObjects.CreateObjectCollection()
				' Add the curve segments to the collection.
				Dim drawCurve As DrawingCurve
				For Each drawCurve In drawcurves
					Dim segment As DrawingCurveSegment
					For Each segment In drawCurve.Segments
						objColl.Add (segment)
					Next
				Next
				Dim colorLayer As Layer
				colorLayer = ThisDoc.Document .StylesManager.Layers.Item("Holes")
				' Change the layer of all of the segments.
				Call drawView.Parent.ChangeLayer(objColl, colorLayer)
			On Error GoTo 0
		End If 'ends if hole feature
   	Next 'feature
End Sub
Sub CreateLayer
	oDoc = ThisDoc.Document
	' Verify that a layer exists for this color.
	Dim layers As LayersEnumerator
	layers = oDoc.StylesManager.Layers
	colorLayer = layers.Item("Holes")
	If Err.Number <> 0 Then
		On Error GoTo 0
		'set to magenta
		Dim newColor As color
		newColor = ThisApplication.TransientObjects.CreateColor(255, 0, 255)
		' Copy an arbitrary layer giving it the name
		' of the render style.
		colorLayer = layers.Item(1).Copy("Holes")
		' the attributes of the layer to use the color,
		' have a solid line type, and a specific width.
		colorLayer.Color = newColor
		colorLayer.LineType = kContinuousLineType
		colorLayer.LineWeight = 0.02
	On Error GoTo 0
End Sub
Message 11 of 11
AdamAG99T
That iLogic code works fine for me, I'm not getting that error at all with a few quick test files I made. Is there any chance you could upload a dummy set of files that causes the error, or at least a screenshot of the full error message. Did the code work without the extra addition to find the hole diameter? Also to be safe what version of inventor are you running?
