Quesitions about MakePath function.
SMillsYS3X2
SMillsYS3X2
I want to use MakePath as a Dim, what variable type should I use? Would the following work?
Dim A as object
A = MakePath({Asm1, Asm2, PRT03})
'Use A in functions
A = MakePath({Asm1, Asm3, PRT28})
'Use A in more function.
etc. etc. etc.
Curtis_W
@SMillsYS3X2 , if you hover over the function name ( MakePath in this case) the tool tip will give you the object type to use for the variable as shown. Hope that helps, Curtis
