Qty in Bom
Qty in Bom
GosponZ
Qty in Bom
GosponZ
please help me to solve this problem. I add custom Part Qty and this column i need to read qty. Same as QTY by default. How i can to get qty. numbers  from QTY column into PartQty. Please see att.
Thanks a lot
jletcher
Go edit the part list and use the item qty in the column chooser and change the column name to part qty.
will do this
hope this is what you was looking for..
GosponZ
Thanks for reply. I do not have problem with qty in part list. I just need map qty to different column on Bom .Reason for that is becouse i exporting bom for my optimizer and it recognise only PartQty
jletcher
Yes that is what I posted for you. even your Qty you can change the name of the column to Part QTY.
