QC Inspection table
HI Guys, I'm working on this code for while, this rule is for create Sketched symbols with counter and place to the all dimensions, while running this code i get the error. the symbol is not placed for some dimensions and this error occurred for that missed dimensions
Sub Main()
AddOrInsertPromptedSymbol()
InsertSymbolsNextToDimensions()
End Sub
Sub AddOrInsertPromptedSymbol()
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim symbolName As String = "My Symbol"
Dim found As Boolean = False
' Check if symbol definition already exists
For Each oSymbolDef As SketchedSymbolDefinition In oDoc.SketchedSymbolDefinitions
If oSymbolDef.Name = symbolName Then
found = True
Exit For
Next
If found Then Return
' Create the sketched symbol definition
Dim oSymbolDefNew As SketchedSymbolDefinition = oDoc.SketchedSymbolDefinitions.Add(symbolName)
Dim oSketch As DrawingSketch = Nothing
oSymbolDefNew.Edit(oSketch)
' Draw a circle and add prompted text box in the symbol sketch
Dim oCenter As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(12, 12)
oSketch.SketchCircles.AddByCenterRadius(oCenter, 0.25)
Dim promptPlaceholder As String = "<Prompt>Enter Text</Prompt>"
Dim oTextBox As TextBox = oSketch.TextBoxes.AddFitted(oCenter, promptPlaceholder)
oSymbolDefNew.ExitEdit(True)
' Do NOT insert the symbol instance here to avoid error on first run
End Sub
Sub InsertSymbolsNextToDimensions()
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSymDef As SketchedSymbolDefinition
' Get the "BA" sketched symbol definition
Try
oSymDef = oDoc.SketchedSymbolDefinitions.Item("My Symbol")
Catch ex As Exception
MsgBox("Sketch Symbol 'BA' not found: " & ex.Message)
Exit Sub
End Try
Dim counter As Integer = 1
Dim offsetX As Double = 0.5
Dim offsetY As Double = 0.2
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
For Each oSheet As Sheet In oDoc.Sheets
Dim oDims As GeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions
For Each oDim As GeneralDimension In oDims
Dim dimPt As Point2d = oDim.Text.Origin
Dim symPt As Point2d = oTG.CreatePoint2d(dimPt.X + offsetX, dimPt.Y + offsetY)
Dim oLeaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
' Create geometry intent at the dimension location
Dim oIntent As GeometryIntent = oSheet.CreateGeometryIntent(oDim, dimPt)
oLeaderPoints.Add(symPt)
oLeaderPoints.Add(oIntent)
Dim promptValues(0) As String
promptValues(0) = counter.ToString()
Try
Dim oSketchedSymbol As SketchedSymbol = oSheet.SketchedSymbols.AddWithLeader(oSymDef, oLeaderPoints, 0, 1, promptValues)
oSketchedSymbol.Static = True
oSketchedSymbol.LeaderVisible = False
MsgBox("Error placing symbol " & counter & ": " & ex.Message)
End Try
counter += 1
Next
Next
End Sub
