PutArcData throws a NotImplementedException
nannerdw
nannerdw
I also tested PutVectorData, and it works as expected.
I'm able to work around this by creating a new Arc3d each time the Radius, StartAngle, or SweepAngle changes.
Is there a better way to do this?  I'm not very familiar with TransientGeometry yet.
iLogic Code:
Imports System.Text 'for StringBuilder
Dim results As StringBuilder = New StringBuilder
Dim tg as TransientGeometry = ThisApplication.TransientGeometry
Dim vec1 As Vector = tg.createVector(1,1,1)
Dim arc1 As Arc3d = tg.CreateArc3d( _
    Center:= tg.CreatePoint(0,0,0), _
    Normal:= tg.CreateUnitVector(0,0,1), _
    ReferenceVector:=tg.CreateUnitVector(1,0,0), _
    Radius:= 1, _
    StartAngle:=0, _
    SweepAngle:=PI)
'PutVectorData Succeeds
Try
    vec1.PutVectorData(coords:={1,1,2})
    results.AppendLine("vec1.PutVectorData Succeeded" & vbNewLine)
Catch ex As Exception
    results.AppendLine("vec1.PutVectorData threw " & TypeName(ex) & vbNewLine)
End Try
'arc1.PutArcData throws a NotImplementedException
Try
    arc1.PutArcData( _
        Center:= {1,1,1}, _
        AxisVector:= {0,0,1}, _
        RefVector:={1,0,0}, _
        Radius:= 1, _
        StartAngle:=0, _
        SweepAngle:=PI)
    results.AppendLine("arc1.PutArcData Succeeded")
    results.AppendLine("arc1.PutArcData threw " & TypeName(ex) & vbNewLine)
End Try
'arc1.Center.PutPointData Succeeds
Try
    arc1.Center.PutPointData({1,1,1})
    results.AppendLine("arc1.Center.PutPointData Succeeded" & vbNewLine)
    results.AppendLine("arc1.Center.PutPointData threw " & TypeName(ex) & vbNewLine)
End Try
'arc1.Normal.PutUnitVectorData Succeeds
Try
    arc1.Normal.PutUnitVectorData({0,1,0})
    arc1.Normal.PutUnitVectorData({0,0,1})
    results.AppendLine("arc1.Normal.PutUnitVectorData Succeeded" & vbNewLine)
    results.AppendLine("arc1.Normal.PutUnitVectorData threw " & TypeName(ex) & vbNewLine)
End Try
'arc1.ReferenceVector.PutUnitVectorData Succeeds
Try
    arc1.ReferenceVector.PutUnitVectorData({0,1,0})
    arc1.ReferenceVector.PutUnitVectorData({1,0,0})
    results.AppendLine("arc1.ReferenceVector.PutUnitVectorData Succeeded" & vbNewLine)
    results.AppendLine("arc1.ReferenceVector.PutUnitVectorData threw " & TypeName(ex) & vbNewLine)
End Try
'arc1.Radius throws a NotImplementedException
Try
    arc1.Radius = 2
    results.AppendLine("arc1.Radius Succeeded" & vbNewLine)
    results.AppendLine("arc1.Radius threw " & TypeName(ex) & vbNewLine)
End Try
'arc1.StartAngle throws a NotImplementedException
Try
    arc1.StartAngle = PI/4
    results.AppendLine("arc1.StartAngle Succeeded" & vbNewLine)
    results.AppendLine("arc1.StartAngle threw " & TypeName(ex) & vbNewLine)
End Try
'arc1.SweepAngle throws a NotImplementedException
Try
    arc1.SweepAngle = PI/2
    results.AppendLine("arc1.SweepAngle Succeeded" & vbNewLine)
    results.AppendLine("arc1.SweepAngle threw " & TypeName(ex) & vbNewLine)
End Try
MessageBox.Show(results.ToString, "Test Results")
Tested with Inventor 2016 and 2018 in Windows 10.
BrianEkins
You're right.  It's likely this code was never completed.  But it is also very rarely used because this has been a part of the API since almost the beginning of the API and you might be the first person to notice it.  It also fails when I try to set the individual properties on the arc.  The simple workaround is to just create a new Arc3D object instead of modifying the existing one.
Brian Ekins
