Purge DWG items when exporting from IV - ilogic
tuliobarata
tuliobarata
Hey all again,
Here im with the following code, that I use to export my iIDW to DWG, but, in my design data i got many styles that i dont use in every IDW, so in someones they are useless, and even useless, they go to the DGW version (like many layers that isnt in use in the drawing).
Now the question, is there a way to purge the document while it is exported from Inventor ?
Because its a little annoying to enter in every DWG file and purge them. The main problem here is the size of files, to send to the client (a request from them, the DWG... not PDF :S )
I'm using this code to export:
'------- start of iLogic code ------------------------------------------------------------------------------------------------------------------------------------- ' Get the DWG translator Add-In. Dim DWGAddIn As TranslatorAddIn
DWGAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'Set a reference to the active document Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Check whether the translator has 'SaveCopyAs' options If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
    ' DWG version.    ' 23 = ACAD 2000    ' 25 = ACAD 2004    ' 27 = ACAD 2007    ' 29 = ACAD 2010     oOptions.Value("DwgVersion") = 29
Dim strIniFile As String
strIniFile = "X:\10-ARQUIVOS INVENTOR\00-Inventor\00 - Inventor 2013\Configuration Files - DWG.ini"
' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile
'get path and file namepath_and_name = ThisDoc.PathAndFileName(False) ' without extension
'Set the DWG target file nameoDataMedium.FileName = path_and_name & ".DWG"
DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------- end of iLogic code ----------------------------------------------------------------------------------------------------------------------------
 Thanks very much!
Tulio Barata
IV 2013
xiaodong_liang
Autodesk Support
Autodesk Support
About purge styles, you could either execute the built-in command by
CommandManager.ControlDefinitions("PurgeStylesCmd").Execute
or delete the style if it is NOT in use. e.g.
Sub replaceAndpurge()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oStyleManager As DrawingStylesManager
Set oStyleManager = oDoc.StylesManager
Dim oBalloonStyle1 As BalloonStyle
Set oBalloonStyle1 = oStyleManager.BalloonStyles("Copy of Balloon (ANSI)")
Dim oBalloonStyle2 As BalloonStyle
Set oBalloonStyle2 = oStyleManager.BalloonStyles("Balloon (ANSI)")
'replace
oStyleManager.ObjectDefaultsStyles(1).BalloonStyle = oBalloonStyle2
'purge
If oBalloonStyle1.InUse And oBalloonStyle1.StyleLocation = kLocalStyleLocation Then
oStyle.Delete
End Sub
