Provide multiple fonts in single ModelLeaderNoteDefinition
ramasamy_thangaperumal
Message 1 of 11
I want to provide different font size in one Model Leader note definition like attached image. Is there any possible way to do this?
Replies (10)
Message 2 of 11
FINET_Laurent
Hi @ramasamy_thangaperumal,
You could use the Formatted Text property as folowing :
Dim o As Inventor.ModelLeaderNote = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "")
o.Definition.Text.FormattedText = "<StyleOverride FontSize='0,6'>4</StyleOverride>(4x)"
What you can do to get the  actual string on line 2 is format the text, copy it co clip board (ctrl + c) & paste it in the code afterwards :
My.Computer.Clipboard.SetText(o.Definition.Text.FormattedText.ToString)
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 11
gerrardhickson
@FINET_Laurent is right - use the FormattedText property.
Whenever I want to set formatting for drawing views (or other objects) I manually set the object as an example, use VBA to extract the formatted text string, then paste it back to my code like @FINET_Laurent suggested, but you'll want to build your own string by replacing the text you manually typed with the text generated by your code.
Message 4 of 11
Thanks for the quick reply. It is working for me. Like this can we able to change the color?
Message 5 of 11
gerrardhickson
Yes - its the same process... Manually create a text box and change the colour, then have a look at the FormattedText property in VBA, and adjust it to suit your needs.
Message 6 of 11
Can you share me sample code? FormattedText = <styleoverride color="Here what should i need to provide(RGB / color name)">.
Message 7 of 11
gerrardhickson
My apologies - you set the text colour using the color property - sample code below.
The TransientObjects.CreateColour() method uses 3 inputs as RGB values between 0 and 255.
Sub GetFormattedText()
Dim oSS As SelectSet
Set oSS = ThisApplication.ActiveDocument.SelectSet
Dim oObj As Object
Dim oTB As GeneralNote
Dim oCol As Color
Set oCol = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
For Each oObj In oSS
    If oObj.Type = kGeneralNoteObject Then
        oTB.Color = oCol
Next oObj
End Sub
 Unfortunately it appears that you can't change SOME of your text - you must change the colour of the whole text box only.
I hope that helps.
Message 8 of 11
@gerrardhickson Thanks for your support. Actually, I want to change multiple color like how I am trying to change multiple font size.
Here for text "4" I am setting one font size. like same way I want to change color only for text"4x".
text = 4(4x)
Message 9 of 11
gerrardhickson
Hi, I understand what you hope to do, but I don't believe it is possible.
Message 10 of 11
Thanks @gerrardhickson . @FINET_Laurent Can you support me on this color change code?
Message 11 of 11
FINET_Laurent
Indeed you can only have one color for the whole text note.
To get the color of an existing one (already formatted), here is the code :
Dim rgb As String = o.Definition.Text.Color.Red & " - " & o.Definition.Text.Color.Green & " - " & o.Definition.Text.Color.Blue
MsgBox(rgb)
To create a new color and set it to the selected note, here is the code :
Dim c As Inventor.Color = ThisApplication.TransientObjects.CreateColor(100, 150, 200)
o.Definition.Text.Color = c
About colors : https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=TransientObjects_CreateColor
Note you can mark multiples replies as solution in the same post.
Kind regards,
FINET L.
