Proper document update before sending data to Excel
adam_liska9KKD3
adam_liska9KKD3
Hi guys. I have a simple rule for export and import data from Excel sheet. I need to update the document before data exchange occurs.
I run the rule through the Forms, but it works with an old data for the first try. I have to run it twice to get it updated properly. Am I missing something?
InventorVb.DocumentUpdate()
If P1_A>0 Then
	GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "G31") = P1_A
If P1_B>0 Then
	GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "H31") = P1_B
P1__SsO = GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "AA9")
P1__SsC = GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "AA10")
GoExcel.Save
Andrii_Humeniuk
Hi @adam_liska9KKD3 . Try this code:
Dim oDoc As Document = ThisDoc.Document
oDoc.Rebuild()
oDoc.Update()
If P1_A>0 Then
If P1_B>0 Then
GoExcel.Save
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
adam_liska9KKD3
No luck...
adam_liska9KKD3
@Andrii_Humeniuk  I´ve found a workaround. I split the rule into 2 rules:
1. document update "DocUpdate"
oDoc.Rebuild()
oDoc.Update()
2. data exchange. "DataExchange"
If P1_A>0 Then
If P1_B>0 Then
GoExcel.Save
And I combined them together in the third rule "Update":
iLogicVb.RunRule("DocUpdate")
iLogicVb.RunRule("DataExchange")
A.Acheson
Hi @adam_liska9KKD3
Try this using the Parameter function.
Parameter.UpdateAfterChange = True
If P1_A>0 Then
	GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "G31") = Parameter("P1_A")
If P1_B>0 Then
	GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "H31") = Parameter("P1_B")
Parameter("P1__SsO") = GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "AA9")
Parameter("P1__SsC")= GoExcel.CellValue(P1__EXCEL + ".xlsx", "VYPOCET", "AA10")
GoExcel.Save
Regards
Alan
