Prompt or message box if specific values not found
JohnBoySarcia
JohnBoySarcia
Hi, good day.
May I kindly ask if there's an ilogic rule to trap if the values don't exist on the given table.
For example:
oList.Add("6" & "|" & "XS" & "|" & 168.275 & "|" & 10.973 & "|" & 146.329)
oList.Add("6" & "|" & "120" & "|" & 168.275 & "|" & 14.275 & "|" & 139.725)
If my oValues (0) = "6" and my oValues (1) = "100" then there should be an error, alert or messagebox
Is this possible?
A.Acheson
Hi @JohnBoySarcia
Can you confirm what the purpose of the "|" is in the string array? Is this a simple list of string or are you concatenating the whole string together. Can you supply an image of what it looks like displayed to the user?
Are you using a list (Of String)
If so you can use a
If oList.Contains("100") then
Can you supply more of the code where you are setting the list object and what value your trying to detect. Will it always be 100?
Regards
Alan
JohnBoySarcia
This is a string array to separate values like a column
For Each oRow In oList
    oValues = Split(oRow, "|")
A.Acheson
Is a method for checking value in a list of string instead of using string array and splitting the string.. Can you share the whole sample your working with and put in the logic that your looking to achieve even in words. It is hard to figure out what your looking to achieve.
Dim list As New List(Of String)
list.AddRange({"er", "ert", "tyu" })
d0 = InputListBox("Prompt", list, d0, Title := "Title", ListName := "List")
If Not list.Contains("123") Then
	MessageBox.Show("123 doesn't exist", "Title")
Regards
Alan
JohnBoySarcia
Dim psize As String = Size
Dim psch As String = Schedule
Dim oList As New ArrayList
For each oRow In oList
oValues = Split (oRow, "|")
If oValues(0) = psize AndAlso oValues (1) = psch Then
d0 = oValues(2)
d1 = oValues(3)
d2 = oValues (4)
Exit For
'This is the simplified program. Now if my size = 6 and sch = 100 as actual selected values, then it should give a message that it was not on the list. Currently it just do nothing and retain the last working values
A.Acheson
I couldn't find any errors. Here is a method with boolean check.
Dim psize As String = "6"
Dim psch As String = "XS"
oList.Add("3" & "|" & "120" & "|" & 168.275 & "|" & 14.275 & "|" & 139.725)
d0 = InputListBox("Prompt", oList, d0, Title := "Title", ListName := "List")
Dim check As Boolean = False
For Each oRow As String In oList
	Logger.Info(oValues(0) & " - " & oValues(1))
	If oValues(0) = psize AndAlso oValues(1) = psch Then
		check = True
		MessageBox.Show("Entered Size & Sch found", "Title")
		d0 = oValues(2)
		d1 = oValues(3)
		d2 = oValues(4)
		Exit For
Next
If check = False Then
	MessageBox.Show("Entered Size & Sch not found", "Title")
Regards
Alan
JohnBoySarcia
Although I need to tweak something, it works. Thank you very much for your help
