Prompt Entry
Prompt Entry
fitriakem
Prompt Entry
fitriakem
Hi.
I need to create prompt entry in multiple sheet but with different value and i've make prompt entry as an iproperties custom to set at Form. But, when i insert value, i found that every sheet i create has same value.
Dim oSheet As Sheet = ActiveSheet.Sheet
Dim oBorder As Inventor.Border = oSheet.Border
If oBorder Is Nothing Then Return
Dim oPromptTextBox As TextBox
For Each oTextBox As TextBox In oBorder.Definition.Sketch.TextBoxes
	If (oTextBox.Text = "<ITEM>") Then
		oPromptTextBox = oTextBox
		Continue For
Next
	If oPromptTextBox Is Nothing Then Return
		Dim oPromptEntry = oBorder.GetResultText(oPromptTextBox)
Dim result As String = InputBox("Input ITEM Value", "ITEM", oPromptEntry)
oBorder.SetPromptResultText(oPromptTextBox, result)
iProperties.Value("Custom", "ITEM") = ITEM
marcin_otręba
maybe you could sheare you empty idw file with that border ?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
C_Haines_ENG
Your code doesn't seem to make sense. You are setting the iProperty to the "ITEM" variable but you haven't declared that anywhere. Since "ITEM" isn't declared anywhere it will just put a blank value.
iProperties.Value("Custom", "ITEM") = result
mslosar
Also, prompted entries are saved on a per sheet basis. If you try and set those values either to or from iproperties, you're going to overwrite the property at each sheet.  You'd need to create an iproperty for each sheets value to keep them separate.
