project to show up in configure libraries
kadscad
kadscad
How do you get your project to show up in the components?
I want to copy existing profiles to create new sizes.
Kirk
Inventor 2023
JamieVJohnson2
This is similar to ContentCenter libraries.  I have dealt mostly with those.  Some rules I must follow every year are:
1.  Library file must be in folder specified (easy to check because path is listed, and you can browse to path).
2.  Library file should be read/write, check file properties to make sure it is not read-only.
3.  Library file must be correct version, this is where the update/migrate should be run to synchronizes with same version of Inventor.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
