project proxy geometry in assembly
Covello_O
Message 1 of 9
Covello_O
Hy All
Again I need some help.
In assembly I want to create a new sketch that projects only the studs (and not any hole) that are on the sheet and the inner edges of the sheet too. Then I would export it as a dxf.
I saw here in the forum that this can be achieved with the CreateGeometryProxy or AddProjectingEntity
but I couldn’t figure out how because I lack the necessary knowledge.
Any help will be very appreciated many thanks
I've found this code but here I have to select the entity to project manually
 Dim oAssemDoc As AssemblyDocument = ThisApplication.ActiveDocument
 Dim oAssemDef As AssemblyComponentDefinition = oAssemDoc.ComponentDefinition
 'Select face on part document
 Dim oFace As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select face on part for new sketch")
 If oFace Is Nothing Then Exit Sub
 Dim oOcc As ComponentOccurrence = oFace.ContainingOccurrence
 oOcc.Edit
'Active part document within an open assembly
 Dim oPartDoc As PartDocument = ThisApplication.ActiveEditDocument
 Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
 Dim oSketch As PlanarSketch = oPartDef.Sketches.Add(oFace.NativeObject)
 oSketch.Edit
 oSketch.Name = "ocSketch"
 'oSketch.ExitEdit
 ' Dim oPointProxy As ObjectTypeEnum = oSketch.SketchPoints
 Dim oEntity As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select entity to project")
'Dim oEntity As Object = oFace
 If oEntity Is Nothing Then Exit Sub
 Dim oEntityOcc As ComponentOccurrence = oEntity.ContainingOccurrence
 oEntityOcc.CreateGeometryProxy(oEntity, oEntityProxy)
 oOcc.CreateGeometryProxy(oSketch, oSketchProxy)
 oSketchProxy.AddByProjectingEntity(oEntityProxy)
Replies (8)
Message 2 of 9
nstevelmans
Hi, maybe this can be a start.
Select a face in the  assembly.
Select an Occurrence in the assy (Only works with cylinder studs)
 Sub main
 Dim oAssyDoc As AssemblyDocument = ThisApplication.ActiveDocument
        Dim oAsmCompDef As AssemblyComponentDefinition = oAssyDoc.ComponentDefinition
        Dim oSketches As PlanarSketches = oAsmCompDef.Sketches
        oSketch = oSketches.Add(oFace)
        Dim oOccMaster As ComponentOccurrence = oFace.ContainingOccurrence
        GetEntitiesEdgeLoop(oOccMaster, oFace, oSketch)
        Dim oCC As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select occurrance")
        If oCC Is Nothing Then Exit Sub
        Dim oIntnameCheck As String = oCC.Definition.Document.internalname
        ' Call the function that does the recursion.
        TraverseAssembly(oAssyDoc.ComponentDefinition.Occurrences, 1, oSketch, oIntnameCheck)
        oAssyDoc.Update()
	End Sub
	   Private Sub GetEntitiesEdgeLoop(Occ As ComponentOccurrence, oFace As Face, oSketch As PlanarSketch)
        Dim projectEdges As Edges
        For Each oEdgeLoop As EdgeLoop In oFace.EdgeLoops
            If oEdgeLoop.IsOuterEdgeLoop = True Then
                projectEdges = oEdgeLoop.Edges
                For Each edge In projectEdges
                    Dim oEdgepProxy As Object
                    Occ.CreateGeometryProxy(Edge, oEdgepProxy)
                    oSketch.AddByProjectingEntity(Edge)
                Next
                Exit For
        Next
    End Sub
	 Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, oSketch As PlanarSketch, InterNameCheck As String)
        ' Iterate through all of the occurrence in this collection.  This
        ' represents the occurrences at the top level of an assembly.
        For Each oOcc In Occurrences
            ' Print the name of the current occurrence.
            If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
                Dim oOccInterName As String = oOcc.Definition.Document.internalname
                If oOccInterName = InterNameCheck Then
                    GetEntities(oOcc, oSketch)
            ' Check to see if this occurrence represents a subassembly
            ' and recursively call this function to traverse through it.
            If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                TraverseAssembly(oOcc.SubOccurrences, Level + 1, oSketch, InterNameCheck)
        Next
    End Sub
	  Private Sub GetEntities(Occ As ComponentOccurrence, oSketch As PlanarSketch)
        ' Because we need the sketch line in the context of the assembly
        ' we need to create a proxy for the sketch line. The proxy
        ' represents the sketch line in the context of the assembly.
        Dim oEdge As Edge = Nothing
        Dim oPartCompdef As PartComponentDefinition = Occ.Definition
        Dim oSurfacebody As SurfaceBody = oPartCompdef.SurfaceBodies.Item(1)
        oEdge = oSurfacebody.Edges.Item(1)
        Dim oEdgeproxy As Object
        Occ.CreateGeometryProxy(oEdge, oEdgeproxy)
        oSketch.AddByProjectingEntity(oEdgeproxy)
    End Sub
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Message 3 of 9
Covello_O
Hi
Thank you very much for taking the time to write this code of lines.
It works perfectly. And also thanks for commenting it.
I can definitely start with it
The only thing that I would like to change is that if the occ has another name, for instance M6x15 and M6x20 than I have to make two sketches.
So instead to pick an occurence manualy its maybe better to ask the user with an InputBox that looks for a  string in the occ name and projects all occ with that name to the scatch?
What would you suggest?
Message 4 of 9
nstevelmans
Hi, I reworked the code a little
1 create a name for the sketch (same name as the part)
  1. loop trough all sketches a see if the sketch exists (no new sketch will be created, and you can run the code multiple times)
  2. create a loop for selecting multiple occurrences (with escape you can abort)
Sub main
        Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select face on part for new sketch")
        Dim oPartDoc As PartDocument = oFace.Parent.Parent.definition.document
        Dim oPartDocName As String = oPartDoc.DisplayName
        Dim oCharCount As Integer = Strings.Len(oPartDocName)
        Dim oNewName As String = Strings.Left(oPartDocName, (oCharCount - 4))
        If oSketches.Count > 0 Then
            For Each oSketch In oSketches
                If oSketch.Name = oNewName Then
                    oSketch = oSketch
                Else
            Next
        Else
        Do
            oCC = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select occurrance")
            If Not oCC Is Nothing Then
        Loop While Not oCC Is Nothing
        oAssyDoc.Update()
	End Sub
                Next
                Exit For
        Next
    End Sub
        Next
    End Sub
    End Sub
Message 5 of 9
Covello_O
Hi
I tried the code but it throws an error on line 24
Message 6 of 9
nstevelmans
Hi, try to replace
With
Try
OSketch.name = oNewName
Catch
End try
Message 7 of 9
Covello_O
Message 8 of 9
Covello_O
you're the man!
Message 9 of 9
AreeshKumaraN
"Hi, when I try this, the sketch appears in the assembly environment instead of the part. Also, instead of just projecting a specific edge, all the board edges are being projected. Additionally, I want to cut the projected sketch into the affected body. How can I achieve this?"
